Uploading Pricelist
We are having issues uploading pricelist. Using the price list module, we are not being able to upload the price list.
Any step by step instruction for uploading price list would be appreciated.
My quick suggestion is to add a price list manually with one example part, then export it. This will provide you with a template. Add to this document in Excel then try importing it back in.
When you say “uploading”, do you mean DMT?
Did try this, but when imported doesn’t show any parts or give any error message
No, if DMT is the only option then I can use that. I am currently trying to upload from Price List Maintenance.
Is there no error in system monitor either?
You should find the process “Price List Import Export Process” in there somewhere, showing that it either completed, failed, or is pending.
Hi Prakit,
We did a procedure for using them. Here’s the part regarding the import/export, perhaps it’ll help you:
Nancy
