Upgrading 8.03.406b to 8.03.410 on Test database
Correct
Manasa
Sent: Tuesday, November 11, 2014 10:22 AM
Subject: Re: [Vantage] Upgrading 8.03.406b to 8.03.410 on Test database
Maybe I can answer my own question, Once I set up a new Installation on a temp Server, I should create backups of my four datasets (Production, Training,Pilot, & Test) (d:\epicor\mfgsys803) and then on the new server do a restore?
On Tuesday, November 11, 2014 11:00 AM, "Larry Jedik larry.jedik@... [vantage]" <vantage@yahoogroups.com> wrote:
If I set up a new VM or other Test Server and install 8.03.4xx on it, how do I copy over the database and customization's from the Live server?
On Tuesday, November 11, 2014 10:29 AM, "John Driggers waffqle@... [vantage]" <vantage@yahoogroups.com> wrote:
You're absolutely right. Don't touch your live server until you're actually ready to upgrade your live environment.
You need to setup a second server, install your current version (or the next one up) on it and start the upgrade process there.
If you're not virtualized and don't have a second server laying around, you can get by with a VM on your workstation. Performance won't be as good, but as long as your have a decent workstation, it should be workable. A VM will also give you snap shot capabilities and easy cloning, which will be super useful.
If you go this route, grab an SSD for 50-100$, stick that in your box and store the VM there. That should give you plenty of IO (which will likely be your only real concern, performance wise) to ensure conversions don't take forever to run.
Once you have that setup, just take a clone of the VM after installing each 'milestone' version. In the end you should have 8.03, 9, .05 and 10 virtual machines. At this point you can run your DB through each VM like a nice little assembly line until you get all the kinks worked out of your upgrade process.
Once you're comfortable with the upgrade, setup your E10 box, run your current DB through your 'assembly line' and put it into production.
Obviously, I've glossed over most of the detail, but that's the basic process.
On Tue, Nov 11, 2014 at 9:45 AM, larry.jedik@... [vantage] <vantage@yahoogroups.com> wrote:
Vista/Progress question here on Upgrading: we are heading down the long road to upgrading to V.10, but before any of that we need to get our current system which is 8.03.406b up to the latest service pack. I want start by applying this service Pack to our Test database and so in reading the Installation Guide, it says to Stop all the Appservers and the database, and I can do that for the TEST data. but the part I'm hung up on is that in section 2.3 of the guide, it says to install the Service Pack in the mfgsys803 & oe101b directories?
If I do this, wont this affect my "LIVE" installation? I want to be sure I can test this before moving forward with touching anything of our Live data.
Yes I've backed up the Database & system files as well as any custom reports.
< span>anyone able to give me reassurance or guidance?
Larry Jedik
Currier Plastics Inc
Larry Jedik
You need to setup a second server, install your current version (or the next one up) on it and start the upgrade process there.Â
If you're not virtualized and don't have a second server laying around, you can get by with a VM on your workstation. Performance won't be as good, but as long as your have a decent workstation, it should be workable. A VM will also give you snap shot capabilities and easy cloning, which will be super useful. Â
Obviously, I've glossed over most of the detail, but that's the basic process.Â
Â
Â
<div>
  <p></p><p><span>Vista/Progress question here on Upgrading: we are heading down the long road to upgrading to V.10, but before any of that we need to get our current system which is 8.03.406b up to the latest service pack. I want start by applying this service Pack to our Test database and so in reading the Installation Guide, it says to Stop all the Appservers and the database, and I can do that for the TEST data. but the part I&#39;m hung up on is that in section 2.3 of the guide, it says to install the Service Pack in the mfgsys803 &amp; oe101b directories? </span></p><p><span><br></span></p><p><span>If I do this, wont this affect my &quot;LIVE&quot; installation? I want to be sure I can test this before moving forward with touching anything of our Live data.</span></p><p><span><br></span></p><p><span>Yes I&#39;ve backed up the Database &amp; system files as well as any custom reports.</span></p><p><span><br></span></p><p><span>anyone able to give me reassurance or guidance?</span></p><p><span><br></span></p><p><span>Larry Jedik</span></p><p><span>Currier Plastics Inc</span></p><p><span><br></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
<div id="ygrps-yiv-1751120605yiv7521872619ygrp-text">
  <div dir="ltr">You&#39;re absolutely right. Don&#39;t touch your live server until you&#39;re actually ready to upgrade your live environment.<div><br clear="none"></div><div>You need to setup a second server, install your current version (or the next one up) on it and start the upgrade process there.&nbsp;</div><div><br clear="none"></div><div>If you&#39;re not virtualized and don&#39;t have a second server laying around, you can get by with a VM on your workstation. Performance won&#39;t be as good, but as long as your have a decent workstation, it should be workable. A VM will also give you snap shot capabilities and easy cloning, which will be super useful. &nbsp;</div><div>If you go this route, grab an SSD for 50-100$, stick that in your box and store the VM there. That should give you plenty of IO (which will likely be your only real concern, performance wise) to ensure conversions don&#39;t take forever to run.</div><div><br clear="none"></div><div>Once you have that
On Tue, Nov 11, 2014 at 9:45 AM, larry.jedik@… [vantage] <vantage@yahoogroups.com> wrote:
<div>
  <div><span>Vista/Progress question here on Upgrading: we are heading down the long road to upgrading to V.10, but before any of that we need to get our current system which is 8.03.406b up to the latest service pack. I want start by applying this service Pack to our Test database and so in reading the Installation Guide, it says to Stop all the Appservers and the database, and I can do that for the TEST data. but the part I&#39;m hung up on is that in section 2.3 of the guide, it says to install the Service Pack in the mfgsys803 &amp; oe101b directories?&nbsp;</span></div><div><span><br clear="none"></span></div><div><span>If I do this, wont this affect my &quot;LIVE&quot; installation? I want to be sure I can test this before moving forward with touching anything of our Live data.</span></div><div><span><br clear="none"></span></div><div><span>Yes I&#39;ve backed up the Database &amp; system files as well as any custom reports.</span></div><div><span><br
clear=“none”>
Larry Jedik
</div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619 -- #ygrps-yiv-1751120605yiv7521872619ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp #ygrps-yiv-1751120605yiv7521872619hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp #ygrps-yiv-1751120605yiv7521872619ads {
margin-bottom:10px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp .ygrps-yiv-1751120605yiv7521872619ad {
padding:0 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp .ygrps-yiv-1751120605yiv7521872619ad p {
margin:0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mkp .ygrps-yiv-1751120605yiv7521872619ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ygrp-lc #ygrps-yiv-1751120605yiv7521872619hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ygrp-lc .ygrps-yiv-1751120605yiv7521872619ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity span {
font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity span span {
color:#ff7900;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619activity span .ygrps-yiv-1751120605yiv7521872619underline {
text-decoration:underline;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619attach div a {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619attach label a {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619bold a {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 dd.ygrps-yiv-1751120605yiv7521872619last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 dd.ygrps-yiv-1751120605yiv7521872619last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 dd.ygrps-yiv-1751120605yiv7521872619last p span.ygrps-yiv-1751120605yiv7521872619yshortcuts {
margin-right:0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619attach-table div div a {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619attach-table {
width:400px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619file-title a, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619file-title a:active, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619file-title a:hover, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619file-title a:visited {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619photo-title a, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619photo-title a:active, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619photo-title a:hover, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div.ygrps-yiv-1751120605yiv7521872619photo-title a:visited {
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 div#ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg #ygrps-yiv-1751120605yiv7521872619ygrp-msg p a span.ygrps-yiv-1751120605yiv7521872619yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619green {
color:#628c2a;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 o {
font-size:0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619photos div {
float:left;width:72px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619reco-category {
font-size:77%;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619reco-desc {
font-size:77%;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 .ygrps-yiv-1751120605yiv7521872619replbq {
margin:4px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg select, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 input, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg pre, #ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 code {
font:115% monospace;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-mlmsg #ygrps-yiv-1751120605yiv7521872619logo {
padding-bottom:10px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-msg p#ygrps-yiv-1751120605yiv7521872619attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-reco #ygrps-yiv-1751120605yiv7521872619reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-sponsor #ygrps-yiv-1751120605yiv7521872619ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1751120605 #ygrps-yiv-1751120605yiv7521872619 #ygrps-yiv-1751120605yiv7521872619ygrp-vital ul li:last-child {
border-right:none !important;}
<div id="ygrps-yiv-613965440yiv4426076579ygrp-text">
  <div style="color:rgb(0, 0, 0);font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;background-color:rgb(255, 255, 255);"><div><span>If I set up a new VM or other Test Server and install 8.03.4xx on it, how do I copy over the database and customization&#39;s from the Live server?&nbsp;</span></div> <div class="ygrps-yiv-613965440yiv4426076579qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-613965440yiv4426076579yqt7369669954" id="ygrps-yiv-613965440yiv4426076579yqt41893"><div class="ygrps-yiv-613965440yiv4426076579yahoo_quoted" style="display:block;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:16px;"> <div dir="ltr"> <font size="2" face="Arial"> On Tuesday, November 11, 2014 10:29 AM, &quot;John Driggers waffqle@... [vantage]&quot;
<div>
clear=“none”>
Larry Jedik
</div>
</div>
</div>
<div class="ygrps-yiv-613965440yiv4426076579yqt7369669954" id="ygrps-yiv-613965440yiv4426076579yqt18446"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579 -- #ygrps-yiv-613965440yiv4426076579ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp hr {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp #ygrps-yiv-613965440yiv4426076579hd {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp #ygrps-yiv-613965440yiv4426076579ads {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp .ygrps-yiv-613965440yiv4426076579ad {
padding:0 0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp .ygrps-yiv-613965440yiv4426076579ad p {
margin:0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mkp .ygrps-yiv-613965440yiv4426076579ad a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ygrp-lc {
font-family:Arial;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ygrp-lc #ygrps-yiv-613965440yiv4426076579hd {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ygrp-lc .ygrps-yiv-613965440yiv4426076579ad {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579actions {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity span {
font-weight:700;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity span:first-child {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity span a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity span span {
color:#ff7900;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579activity span .ygrps-yiv-613965440yiv4426076579underline {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579attach {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579attach div a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579attach img {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579attach label {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579attach label a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579bold {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579bold a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 dd.ygrps-yiv-613965440yiv4426076579last p a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 dd.ygrps-yiv-613965440yiv4426076579last p span {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 dd.ygrps-yiv-613965440yiv4426076579last p span.ygrps-yiv-613965440yiv4426076579yshortcuts {
margin-right:0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579attach-table div div a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579attach-table {
width:400px;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579file-title a, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579file-title a:active, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579file-title a:hover, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579file-title a:visited {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579photo-title a, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579photo-title a:active, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579photo-title a:hover, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div.ygrps-yiv-613965440yiv4426076579photo-title a:visited {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 div#ygrps-yiv-613965440yiv4426076579ygrp-mlmsg #ygrps-yiv-613965440yiv4426076579ygrp-msg p a span.ygrps-yiv-613965440yiv4426076579yshortcuts {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579green {
color:#628c2a;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 o {
font-size:0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579photos div {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579photos div div {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579photos div label {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579reco-category {
font-size:77%;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579reco-desc {
font-size:77%;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 .ygrps-yiv-613965440yiv4426076579replbq {
margin:4px;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-actbar div a:first-child {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg table {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg select, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 input, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 textarea {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg pre, #ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 code {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg * {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-mlmsg #ygrps-yiv-613965440yiv4426076579logo {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-msg p a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-msg p#ygrps-yiv-613965440yiv4426076579attach-count span {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-reco #ygrps-yiv-613965440yiv4426076579reco-head {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-reco {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ov li a {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ov li {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-sponsor #ygrps-yiv-613965440yiv4426076579ov ul {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-text {
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-text tt {
font-size:120%;}
#ygrps-yiv-613965440 #ygrps-yiv-613965440yiv4426076579 #ygrps-yiv-613965440yiv4426076579ygrp-vital ul li:last-child {
yes, though I wouldn't bother doing them all.. Just pick one and do your thing with it. No need for all that conversions and crazy things.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Nov 11, 2014 at 11:22 AM, Larry Jedik larry.jedik@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div><span>Maybe I can answer my own question, Once I set up a new Installation on a temp Server, I should create backups of my four datasets (Production, Training,Pilot, &amp; Test) (d:&#92;epicor&#92;mfgsys803) and then on the new server do a restore?</span></div><div><div> <div><br><br></div><div> <div style="font-family:HelveticaNeue,;font-size:16px;"> <div style="font-family:HelveticaNeue,;font-size:16px;"> <div dir="ltr"> <font face="Arial"> On Tuesday, November 11, 2014 11:00 AM, &quot;Larry Jedik <a rel="nofollow" target="_blank" href="mailto:larry.jedik@...">larry.jedik@...</a> [vantage]&quot; &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt; wrote:<br> </font> </div>  <br><br> <div><div><div>
Â
<div>
  <div style="color:rgb(0,0,0);font-family:HelveticaNeue,;font-size:16px;background-color:rgb(255,255,255);"><div><span>If I set up a new VM or other Test Server and install 8.03.4xx on it, how do I copy over the database and customization&#39;s from the Live server? </span></div> <div><br clear="none"><br clear="none"></div><div><div> <div style="font-family:HelveticaNeue,;font-size:16px;"> <div style="font-family:HelveticaNeue,;font-size:16px;"> <div dir="ltr"> <font face="Arial"> On Tuesday, November 11, 2014 10:29 AM, &quot;John Driggers <a rel="nofollow" target="_blank" href="mailto:waffqle@...">waffqle@...</a> [vantage]&quot;
Â
<div>
  <div dir="ltr">You&#39;re absolutely right. Don&#39;t touch your live server until you&#39;re actually ready to upgrade your live environment.<div><br clear="none"></div><div>You need to setup a second server, install your current version (or the next one up) on it and start the upgrade process there. </div><div><br clear="none"></div><div>If you&#39;re not virtualized and don&#39;t have a second server laying around, you can get by with a VM on your workstation. Performance won&#39;t be as good, but as long as your have a decent workstation, it should be workable. A VM will also give you snap shot capabilities and easy cloning, which will be super useful.  </div><div>If you go this route, grab an SSD for 50-100$, stick that in your box and store the VM there. That should give you plenty of IO (which will likely be your only real concern, performance wise) to ensure conversions don&#39;t take forever to run.</div><div><br clear="none"></div><div>Once you have that
Â
Â
<div>
  <div><span>Vista/Progress question here on Upgrading: we are heading down the long road to upgrading to V.10, but before any of that we need to get our current system which is 8.03.406b up to the latest service pack. I want start by applying this service Pack to our Test database and so in reading the Installation Guide, it says to Stop all the Appservers and the database, and I can do that for the TEST data. but the part I&#39;m hung up on is that in section 2.3 of the guide, it says to install the Service Pack in the mfgsys803 &amp; oe101b directories? </span></div><div><span><br clear="none"></span></div><div><span>If I do this, wont this affect my &quot;LIVE&quot; installation? I want to be sure I can test this before moving forward with touching anything of our Live data.</span></div><div><span><br clear="none"></span></div><div><span>Yes I&#39;ve backed up the Database &amp; system files as well as any custom reports.</span></div><div><span><br clear="none"></span></div><div><span>anyone able to give me reassurance or guidance?</span></div><div><span><br clear="none"></span></div><div><span>Larry Jedik</span></div><div><span>Currier Plastics Inc</span></div><div><span><br clear="none"></span></div>
</div>
</div>
<div style="color:#fff;min-height:0;"></div></div>
</div>
<div><div style="color:#fff;min-height:0;"></div></div>
</div><div><div>
