Does anyone know if I have to install the 32 bit version to do a migration of a 32 bit Vantage database, I had uninstalled Vantage 9.05.007 because of the issue I was having upgrading the database from 9.4 to 9.5x so I uninstalled everything to start from scratch. Now I cannot connect to the database when I reinstall everything. I was installing the 64bit OpenEdge.
If anyone can help me out on this I surely would appreciate it. I need to get this done this weekend. There may be 2 post from me on this, I’m not sure if the other one saved.
Thank you,
aidacra
(Nathan your friendly neighborhood Support Engineer)
2
You do not need the 32 bit install of 905/open edge to upgrade from 32bit
803.
was there an error in the database log when you tried to start it? The db
log should be named mfgsys.lg in the same folder as the db itself.
I noticed when I uninstalled the openedge on the server there was a different named OpenEdge 10.2, it was a longer description. I noticed on another website that the CD version may have a problem and not to install that one, but the downloadable from Epicor. I’ve tried all last night trying to get this to work. I was never able to open the progress explorer after I reinstalled everything. So I am not able to start the database. Also having troubles reinstalling the OpenEdge from the DC version, so I’m going to try the downloadable from Epicor.
