Upgrade to v2024 EpicorRESTAPICore UnAuthorized
We upgraded our DEV and QA environments to v2024.2.4 and I am now getting Unauthorized when I try to make calls from my code.
We do not have issues in PROD running v2023
using EpicorRESTAPICore v2.2.0.2
using PostMan or the Resthelp seems to run fine.
Anyone else having issues with v2024 and the RestAPI?
if (EpicorRest.CreateBearerToken())
    MultiMap<string, string> iparams = new MultiMap<string, string>();
    iparams.Add("$select", "Company,MfgNum,MfgID,Name,Inactive");
    iparams.Add("$top", "10000");
    iparams.Add("$skip", $"{skipCount}");
    iparams.Add("$count", "false");
    var eri = await EpicorRest.BoGetAsync("Erp.BO.ManufacturerSvc", "Manufacturers", iparams);
    if (eri.ResponseStatus == System.Net.HttpStatusCode.OK)
Do you use REST v1? Does your user have it enabled in for the user? table Ice.SysUserFile
Can we see the rest of your code how are you setting up the RestCall
EpicorRest.AppPoolHost = DBManager.EpicorAppPoolHost;
EpicorRest.AppPoolInstance = DBManager.EpicorAppPoolInstance;
EpicorRest.UserName = "¿?¿?¿?¿?";
EpicorRest.Password = "¿?¿?¿?¿?¿?";
EpicorRest.Company = Company;
EpicorRest.APIKey = APIKey; //out of date example: MlXImApzhuEI7AOfZzZZfzDDqeMMywPWZXK62ZTsZax4I
EpicorRest.APIVersion = EpicorRestVersion.V2; //Defaults to V2
EpicorRest.License = EpicorLicenseType.Default;
EpicorRest.IgnoreCertErrors = false;
EpicorRest.Timeout = epicorTimeoutMS; //ms (900*1000)
EpicorRest.MaxRequestLogLength = 1;
        ManufacturerSvc r = JsonConvert.DeserializeObject<ManufacturerSvc>(eri.ResponseData.ToString());
        if (r?.Manufacturers?.Count > 0)
            mfgs.AddRange(r.Manufacturers);
            if (r.Manufacturers.Count == topCount)
                //need to go get more
                var moreMfgs = await GetManufacturers(frmWait, skipCount + topCount);
                if (moreMfgs?.Count > 0) mfgs.AddRange(moreMfgs);
            return mfgs;
    else
        ErrorDialog.Show($"GetManufacturers ResponseError", eri, "", new System.Diagnostics.StackTrace(true).ToString());
That’s trippy. Love it.
Monster Cookie GIF
alt code 0191
just one that I always remember, lol
FYI: the fix here was to recycle the AppPool to fix the UnAuthorized calls.
