We are upgrading from 9.05.607b/SQL to 9.05.702a/SQL; moving to new app and db servers in the process. I've run the schema changes and the conversions, started up the primary appserver and cleaned out the old system tasks. Now, when I try to start up the TaskAgent and Process Server, the TaskAgent seems to timeout after a little more than 3 minutes while trying to connect to the database, giving the following error:
[14/05/19@12:45:50.892-0400] P-006756 T-003332 1 AS -- (Procedure: 'agent/TaskAgent.p' Line:1892) Task Agent SystemTaskAgent has been started
[14/05/19@12:49:10.304-0400] P-006756 T-003332 1 AS -- (Procedure: 'purgeHistory agent/TaskAgent.p' Line:2573) Disconnecting database Epicor905 due to server communication failure (14959)
None of the task history is cleaned up and the configured schedules do not start.
Anyone have any experience dealing with such an issue or have any thoughts about what's going on?
Bob Beaghan
