Upgrade to 8.0x - Data Conversion
--- In vantage@yahoogroups.com, "Brian Boyes" <Brian.Boyes@...>
wrote:
> > I don't know if you can go from 8.0-8.03.400 because I didn't do
that
> upgrade so I don't know if there is a schema change to run through.
> Yes, you have to do a schema change and conversion for each version
> change. So you'd need 6.1->8.0, 8.0->8.03.305, and then 8.03.305 ->
> 8.03.400
> > .400 is more of a patch, it's not nearly as time consuming.
> It's a full install, complete with a new version of Openedge. The
only
> reason I found it less time consuming was because by the time I
got to
> the conversion to .400, I'd already done so many conversions, I was
> getting good at it.
> Brian
Could you tell me where to find documention in epicor site for
installing 8.03.400 because cannot see any in download site for
progress
thanks
kirsty
We are looking into upgrading to version 8.0x. We have a copy of 8.0 and have successfully done an upload of our data from 6.1 to 8.0. We now want to load in 8.03 and transfer "latest" data to 8.03.
Can I easily upload data from 6.1 directly to 8.03 or 8.04? If so, how?
What I am being told is you have to go from 6.1 to 8.0 to 8.03 ... so 2 steps instead of 1.
Also, curious ... is 8.04 upgrade more of a patch type upgrade or is there more too it.
Building a website is a piece of cake.
Yahoo! Small Business gives you all the tools to get online.
No, you must go through a schema change from 6.1-8.0 then another one
from 8.0-8.03. I don't know if you can go from 8.0-8.03.400 because I
didn't do that upgrade so I don't know if there is a schema change to
run through. .400 is more of a patch, it's not nearly as time
consuming.
Paul
Of Rough Brothers
Sent: Wednesday, September 12, 2007 8:28 AM
To: Vantage Users
Subject: [Vantage] Upgrade to 8.0x - Data Conversion
steps instead of 1.
there more too it.
> I don't know if you can go from 8.0-8.03.400 because I didn't do that
8.03.400
It's a full install, complete with a new version of Openedge. The only
reason I found it less time consuming was because by the time I got to
getting good at it.
Brian
