I am trying to upgrade E10.1.600 on E10.1.500 environment i am following below steps.
- Taking Live DB backup restored on Test environment using administrator console of Epicor kept for Database upgrade during that process I am getting below error message .
Starting Preparation
- Ice.Internal.Upgrade.ReportDataDefinition
Preparation Complete: 0.0013117 seconds
Starting Execution Phase…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Upgrading customized Report Data Definitions
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptTable records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptTable Records Affected: 0
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptRelation records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptRelation Records Affected: 0
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptRelationField records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptRelationField Records Affected: 0
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptCalcField records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptCalcField Records Affected: 0
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptLinkTable records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptLinkTable Records Affected: 0
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Process Ice.RptLinkField records…
Information Ice.Internal.Upgrade.ReportDataDefinition Ice.Internal.Upgrade.ReportDataDefinition~ Ice.RptLinkField Records Affected: 0
Execute Phase Complete: 1.3929566 seconds
Starting Cleanup Phase…
Cleanup Phase: 0.000676 seconds
- SSRS Breaking/Routing Rules
Preparation Complete: 0.0006852 seconds
Information SSRS Breaking/Routing Rules SSRS Breaking/Routing Rules~ Starting upgrade for SSRS Breaking/Routing rules.
Information SSRS Breaking/Routing Rules SSRS Breaking/Routing Rules~ Upgrade for SSRS Breaking/Routing rules completed successfully.
Execute Phase Complete: 0.0052626 seconds
Cleanup Phase: 0.0007221 seconds
- Post Migration
Preparation Complete: 0.0021046 seconds
- Post Migration
Information Post Migration Post Migration ~ Executing: ICE3_ExtendedEvents.sql
Information Post Migration Post Migration ~ Executing: BackupXXXDefXXXChunk.sql
Information Post Migration Post Migration ~ Executing: CaptureLogCleanup.sql
Information Post Migration Post Migration ~ Executing: CleanupCacheAndAssemblyStore.sql
Information Post Migration Post Migration ~ Executing: DeleteFromSysTask.sql
Information Post Migration Post Migration ~ Executing: InsertZDataFieldwithUD.sql
Information Post Migration Post Migration ~ Executing: Set_IDENTITY_INSERT_OFF.sql
Information Post Migration Post Migration ~ Executing: SyncUDRows.sql
Error Post Migration SyncUDRows.sql Invalid object name ‘dbo.Budget’.
DELETE UDTable
FROM [dbo].[Budget_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [dbo].[Budget] a
WHERE a.SysRowID = UDTable.ForeignSysRowID)
INSERT INTO [dbo].Budget_UD
SELECT SysRowID FROM [dbo].[Budget] a
WHERE NOT EXISTS (SELECT 1 FROM [dbo].[Budget_UD] b
WHERE b.ForeignSysRowID = a.SysRowID)
DELETE UDTable
FROM [Erp].[GLJrnDtl_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[GLJrnDtl] a
INSERT INTO [Erp].GLJrnDtl_UD
SELECT SysRowID FROM [Erp].[GLJrnDtl] a
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[GLJrnDtl_UD] b
DELETE UDTable
FROM [Erp].[GLJrnDtlMnl_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[GLJrnDtlMnl] a
INSERT INTO [Erp].GLJrnDtlMnl_UD
SELECT SysRowID FROM [Erp].[GLJrnDtlMnl] a
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[GLJrnDtlMnl_UD] b
DELETE UDTable
FROM [Erp].[OrderHed_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[OrderHed] a
INSERT INTO [Erp].OrderHed_UD
SELECT SysRowID FROM [Erp].[OrderHed] a
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[OrderHed_UD] b
DELETE UDTable
FROM [Erp].[Part_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[Part] a
INSERT INTO [Erp].Part_UD
SELECT SysRowID FROM [Erp].[Part] a
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[Part_UD] b
DELETE UDTable
FROM [Erp].[RvJrnTrDtl_UD] UDTable
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[RvJrnTrDtl] a
INSERT INTO [Erp].RvJrnTrDtl_UD
SELECT SysRowID FROM [Erp].[RvJrnTrDtl] a
WHERE NOT EXISTS (SELECT 1 FROM [Erp].[RvJrnTrDtl_UD] b
DECLARE @TableSchema sysname,
@TableName sysna
Execute Phase Complete: 4.9187459 seconds
- Post Migration
Cleanup Phase: 0.0025352 seconds
DB Migration process is cancelled by the user.
The total execution time is 0.1071 minutes.
Preparation Complete: 0.0013136 seconds
Execute Phase Complete: 1.3563067 seconds
Cleanup Phase: 0.0006759 seconds
Preparation Complete: 0.0006849 seconds
Execute Phase Complete: 0.0050761 seconds
Cleanup Phase: 0.0007153 seconds
- Post Migration
Preparation Complete: 0.0021184 seconds
- Post Migration
DELETE UDTable
DELETE UDTable
DELETE UDTable
DELETE UDTable
DELETE UDTable
DELETE UDTable
@TableName sysna
Execute Phase Complete: 4.60515 seconds
- Post Migration
Cleanup Phase: 0.0022652 seconds
The total execution time is 0.1012 minutes.
