Updating "Required by" date in the Job
I use the "suggestion" box under job entry. When the box opens up, chose the
job to update, and it will bring you to the "links" screen. From there you
can update, get details, schedule.
Sent: Monday, October 02, 2000 11:22 AM
To: Oneliste (E-mail)
Subject: [Vantage] Updating "Required by" date in the Job.
For all of you using the scheduling function in Vantage. When a required by
date is modified in a sale order have you found a quick way to update the
date in a job. Updating the required by in the job is so tedious: you have
to go into the job header, Un-engineer the job and type the new "required
by" date manually. I do not want to update the required by in two places.
Any suggestions?
Martin Nijdam
Suss Woodcraft Int'l
(514) 363-3565
Any suggestions?
Martin Nijdam
(514) 363-3565
