Hi
Im trying to update the QuoteDtl.ProjectID field from the Quite Entry form. There is already some extensive code in place on the form so i dont want really want to BPM this if possible.
The ProjectID is being selected like this
bool recSelected;
string whereClause = string.Empty;
System.Data.DataSet dsProjectAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "ProjectAdapter", out recSelected, true, whereClause);
System.Data.DataRow adapterRow = dsProjectAdapter.Tables[0].Rows[0];
Im updating a custom field in the QuoteHed like this
EpiDataView edvQH = ((EpiDataView) (this.oTrans.EpiDataViews["QuoteHed"]));
System.Data.DataRow edvQHR = edvQH.CurrentDataRow;
edvQHR.BeginEdit();
edvQHR["Project_c"] = adapterRow["ProjectID"];
edvQHR.EndEdit();
Thid field update works ok but doing something similar for QuoteDtl fails with a ‘Object not set as a reference’ error. Obviously i am not referencing the correct EpiDataView for QuoteDtl so, what is the correct syntax to do the same in the QuoteDtl.ProjectID field?
