We need to update JobMtl records on open jobs where the parts have not been issued. I would to use DMT to do this, however, all of the jobs have been engineered so DMT gave me an error.
Is there a way I can get these un-engineered, change the needed records, and then engineer them again with DMT? Or will I need to use an updatable dashboard to un-engineer all the jobs and then make the changes with DMT?
You’d have to make a templated that unreleases, unengineers the jobs, then run your material updated and reverse it with your other template. There’s also a flag in company config that allows you tonight make changes to engineered jobs. You could temporarily flip that if it makes sense for you to do so.
