I’m attempting to create an updateable dashboard for Tasks so the users don’t need access to Engineering Workbench, as our engineering team wants to add one of their processes as a task set.
Currently, the built in UpdateExt on Task and TEApproval give an error
I am assuming this is because somewhere in the methods it is calling CheckCompleteIncludingNextTaskWarning rather than what Engineering Workbench calls which is just CheckComplete
So, I turned off the BPM Update and toggled Advanced BPM Update only and started creating a BASE directive.
I filled in a dataset by query, and made sure to grab the real Task’s SysRowID rather than the Query result’s SysRowID just in case (either SysRowID does NOT work, tried both) and ran the Task.CheckComplete method in the BASE directive. The row says it updates without error, but nothing actually changes in the Engineering Workbench.
When I run CheckComplete in a pre-directive rather than base, and provide a dummy base directive or even run it in both directives, it also has the same behavior where nothing actually updates.
If I manually call the Update method in either the Pre or Base directive, it gives the “Row was modified by another user” error meaning the query must be calling the Update or UpdateExt on it’s own anyway at some point, but NOT AFTER the check complete directive fires like in Engineering Workbench.
I see there is a thread where @Aaron_Moreng completed a C# update to the Task properly, but as I’m unable to call the Update method without an error, I can’t really use this for my solution.
Any ideas or am I dead in the water?
EDIT* I also tried the same methodology in the RunCustomAction rather than the Update, with the same results.
