Updateable Dashboard Problems
Hi Everyone
Ive created an updateable baq and dashboard- on clicking ‘Test Application’ i can see the dashboard is updateable.
However on deployment it isnt - please help
Just want to confirm. When you “see” that the dashboard is updatable in Test Application, have you actually updated a record?
When you make your menu item, did you pick assembly dashboard, or runtime dashboard? You have to pick assembly dashboard to do the updateable stuff.
It appeared to do so, but didnt actually.
I figured out the problem in the end, i had setup one field to map incorrectly
thanks everyone
