This has been a common problem with 700C, and the main reason we're still on 700B2. There is a downloadable fix from epicor. I'm not sure if it is on epicweb, but I know you can get it if you call support.
Sent: Saturday, August 18, 2012 1:24 PM
Subject: [Vantage] Re: UPdate to .700C error
Â
I had the same issue going to 700B2. I reinstalled the client and created a new client release from scratch using the custom/patch folder. They release client stuff in 700 (admitted to me by epicor) is not working 100% there are sometimes some strange things that go on with it. If that doesn't work make sure to try logging in with multiple different users to ensure a personalization on the mainmenu is not broken.
Â
--- In vantage@yahoogroups.com, Ned <TechnoBabbly@...> wrote:
> I have not run into this before for any other updates I have done and
> wondering if anyone is checking their mail on the weekend and could shed any
> light on this? I get this error when I startup an Epicor Client, both on the
> server and on a workstation. I had no problems with conversions, but this
> one is puzzling me. I have done a few different .700 updates already and not
> had this error pop up, so I am not sure where to start looking to solve it.
> There don't appear to be any customizations in the .mfgsys file and rolling
> the EpiClientLib file back to the previous version is even worse.
> Could not load file or assembly 'Epicor.Mfg.UI.EpiClientLib,
> Version=2.5.607.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992' or one
> of its dependencies. The located assembly's manifest definition does not
> match the assembly reference. (Exception from HRESULT: 0x80131040)
> Stack Trace
> at System.Reflection.Assembly._GetType(String name, Boolean throwOnError,
> Boolean ignoreCase)
> at System.Reflection.Assembly.CreateInstance(String typeName, Boolean
> ignoreCase, BindingFlags bindingAttr, Binder binder, Object[] args,
> CultureInfo culture, Object[] activationAttributes)
> at Epicor.Mfg.UI.Startup.preLoadAssemblies()
> at Epicor.Mfg.UI.Startup.PreStart(Session session, Boolean
> initializeLanguage)
> at Epicor.Mfg.UI.App.Launch.createInitialSession()
> at Epicor.Mfg.UI.App.Launch.ShowMenuForm()
> at Epicor.Mfg.UI.App.Launch.ShowDialog(String[] args)
