Update table via BPM
I believe the developer’s license built in on Epicor started with 9.04, but I’m not sure. I’m on whatever versions of Progress for that version of Epicor. I support clients on 9.04.507, 9.05.600, 602 and now 603. I believe you can include 4GL on all these without the developer’s license.
Kevin Simon
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Carl Peterson
Sent: Saturday, February 26, 2011 9:24 PM
Subject: Re: [Vantage] Re: Update table via BPM
Are you on version 9 - what version of Progress?
Csrl
Sent from my iPhone
1-734-812-9532 - cell#
On Feb 26, 2011, at 9:04 PM, "Kevin Simon" <ksimon@... <mailto:ksimon%40simstrak.com> > wrote:
> Carl,
> The code I wrote is in a BPM. Depending upon the version of Epicor you're
> on, the 4GL developer's license now comes with the BPM tool. Also, I've
> never had to disable triggers as you mentioned below, and I do these types
> of BPM updates all the time.
> KEvin
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
> Carl Peterson
> Sent: Friday, February 25, 2011 5:35 PM
> Subject: RE: [Vantage] Re: Update table via BPM
> You would need a Progress 4GL Developer's license to update a table like you
> have below and you would have to disable the triggers, too.
> Disable triggers for load of orderrel.
> Disable triggers for dump of orderrel.
> The BPM concept would be less expensive and just as easy.
> Carl Peterson
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> Kevin Simon
> Sent: Thursday, February 24, 2011 7:55 AM
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Michael,
> The following works also, and is a lot easier to write:
> for each OrderRel no-lock:
> ASSIGN OrderRel.Character01 = OrderRel.ShortChar01.
> End.
> Kevin Simon
> Behalf Of
> michael.hutcheson@... <mailto:michael.hutcheson%40rocketmail.com> <mailto:michael.hutcheson%40rocketmail.com>
> Sent: Thursday, February 24, 2011 4:38 AM
> Subject: [Vantage] Re: Update table via BPM
> Its ok folks I missed the closing bracket!!!
> All working.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> ,
> "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> > Hey folks,
> > I want to update the order rel Char01 with the data from ShortChar01 so am
> using the following 4GL code and linking it to a BPM action:
> > Run lib\UpdateTableBuffer.p(input BUFFER OrderRel:HANDLE, 'Character01',
> > End.
> > However, when I click on validate I receive:
> > Error Detail
> > ** Unable to understand after -- "Run". (247)
> > ** Invalid statement. (254)
> > ** Could not understand line 22. (198)
> > I have done loads of these updates before in the past so why is it not
> working now?
> > Regards,
> > Michael
> > Vantage 8.03.406
Hey folks,
I want to update the order rel Char01 with the data from ShortChar01 so am using the following 4GL code and linking it to a BPM action:
Run lib\UpdateTableBuffer.p(input BUFFER OrderRel:HANDLE, 'Character01', OrderRel.ShortChar01.
End.
Error Detail
I have done loads of these updates before in the past so why is it not working now?
Regards,
Michael
Vantage 8.03.406
All working.
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Hey folks,
> End.
> Error Detail
> Regards,
> Michael
> Vantage 8.03.406
Michael,
End.
Kevin Simon
All working.
> Hey folks,
> End.
> Error Detail
working now?
> Regards,
> Michael
> Vantage 8.03.406
Ah, cheers Kevin, I should give it a try...
Michael
--- In vantage@yahoogroups.com, "Kevin Simon" <ksimon@...> wrote:
> Michael,
> End.
> Kevin Simon
> All working.
> "michael.hutcheson@" <michael.hutcheson@> wrote:
> > Hey folks,
> > End.
> > Error Detail
> working now?
> > Regards,
> > Michael
> > Vantage 8.03.406
Carl Peterson
Kevin Simon
Michael,
End.
Kevin Simon
Behalf Of
All working.
> Hey folks,
> End.
> Error Detail
working now?
> Regards,
> Michael
> Vantage 8.03.406
Carl,
KEvin
Carl Peterson
Carl Peterson
Behalf Of
Kevin Simon
Michael,
End.
Kevin Simon
Behalf Of
All working.
> Hey folks,
> End.
> Error Detail
working now?
> Regards,
> Michael
> Vantage 8.03.406
Csrl
Sent from my iPhone
On Feb 26, 2011, at 9:04 PM, "Kevin Simon" <ksimon@...> wrote:
> Carl,
> KEvin
> Carl Peterson
> Carl Peterson
> Behalf Of
> Kevin Simon
> Michael,
> End.
> Kevin Simon
> Behalf Of
> All working.
> > Hey folks,
> > End.
> > Error Detail
> working now?
> > Regards,
> > Michael
> > Vantage 8.03.406
