Hi All,
I need to update JobHead.CheckBox02 when OrderDtl.Checkbox02 is set to true.
how can this be done?
Thanks.
Use a data directive and a condition to find when checkbox2 is changed, make the same change to jobhead using getdatasetfortree, update table by query, and update. You could probably also do this in a function if you don’t want to get into data directives.
The main problem I see is that OrderDtl doesn’t have checkbox fields, so you must have added them as custom fields ahead of time.
Good luck!
The Job number is also on the release line. So you need to take that into account also, unless you have a custom job number field on the OrderDtl.
