Thanks Jose, this is what I have now and appears to work.
Private Function GetNextKey(ByVal company As String) As String
   Dim nextKey As String = String.Empty
   Try
      Dim sessMod As New SessionMod(ProjectEntryForm.Session.ConnectionPool)
      sessMod.GracefulShutdown()
      sessMod.SetCompany(company, "", "", "", "", "", "", "", "")
      sessMod.SetPlant("MfgSys", "")
      Dim co as company = new company(ProjectEntryForm.Session.ConnectionPool)
      Dim cds as companydataset = co.GetByID(company)
         nextKey = cds.Company.Rows(0)("Number05").toString()
         cds.Company.Rows(0).BeginEdit()
         cds.Company.Rows(0)("Number05") += 1
         cds.Company.Rows(0).EndEdit()
         co.Update(cds)
   Catch ex As Exception
      EpiMessageBox.Show(ex.Message)
   End Try
   Return nextKey
End Function
To: Vantage <vantage@yahoogroups.com>
Sent: Monday, December 3, 2012 10:16 AM
Subject: Re: [Vantage] Re: Update Company tables fields
Do this before your code
, Youll have to Birng in the Session Mod Bo's and IF
SessionMod SessionMod = new SessionMod(session.ConnectionPool);****
          SessionMod.GracefulShutdown();****
          SessionMod.SetCompany('YOURCOMPANY', out name, out
plantid, out plant, out workstationid, out workstation, out employee, out
groupcode, out countrycode);****
          SessionMod.SetPlant(plantid, out plant);
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
 <http://www.usdoingstuff.com>
   Try
         co.Update(cds)
   End Try
   Return nextKey
End Function
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, Dec 3, 2012 at 10:08 AM, jckinneman <jckinneman@...> wrote:
> The company table is a bit of a special bird. Almost all business objects
> know what company you are current working in. That is why you don't need to
> specify it on where clauses and the like. I hazard a guess that this
> behavior is interfering with getting another company. You could
> programmaticly change the company you are working with briefly, make the
> change and then set it back but that might be messy and confuse the current
> transaction.
> If you just need to increment the field I would use a BPM and then a
> simple find on the company table and then update the field of interest.
> Other option is a direct progress call to do the update.
> Jim Kinneman
> Encompass Solutions, Inc
> --- In vantage@yahoogroups.com, "tkoch77" <tkoch77@...> wrote:
> > Hi all,
> > I am trying to use Company.GetByID to return the CompanyDataSet and then
> updating a UD field. It works fine when the company ID is the current
> company but fails if I try to perform GetByID on a company other than the
> current company (Logged in company 100 and trying GetByID on company 200).
> Here is what I have, is there something I am missing?
> > Thanks,
> > -Ted
> > Try
> > Dim cds as companydataset = co.GetByID(company)'Fails here
> > co.Update(cds)
> > End Try
> > Return nextKey
> > End Function
>Â
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
