There isn't a 'code-free' way to do it, but if you don't mind writing a bit
it isn't too hard.
The easiest way is to use the customization wizard to add a UD table as a
child. After it wires up the UD table you can change the code to point to
any table you like.
Use a find/replace to swap UDXX for whatever table/BO you want and that
will fix a lot of the code automatically. However, you'll still need to
make a number of changes to get it all working. Just do that and run the
'test code' function. You'll get a TON of errors, but don't be discouraged.
Just go through them one by one and you'll get there.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
On Fri, Oct 5, 2012 at 12:31 PM, supertico05
<mvissuet@...>wrote:
it isn't too hard.
any table you like.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> **[Non-text portions of this message have been removed]
> Is there a way to create an Updatable Foreign Key View on Epicor 9.05.606?
