I am having an issue with an updatable dashboard. When I go to test it from the Test Application button on the deploy dashboard screen, everything works as it should. The fields turn white, and you can change the values.
But when I put it on a menu and drive out to it and run it from there, you are not able to do what it is supposed to. Any ideas?
