Sorry for the delay @bordway ,
I decided to try doing this in a simple example.
This is the BAQ:
One UD field in Customer table (SiteID_c) and two fields on OrderDtl table (NeedByDate and RequestDate).
First I checked the standard code for each one of these using a standard BPM in UBAQ. Here are the codes for each one:
OrderDtl update:
// <auto-generated>
// This code was generated by a tool. Any changes made manually will be lost
// the next time this code is regenerated.
// </auto-generated>
using (var updater = this.getDataUpdater("Erp", "SalesOrder"))
var ttResultQuery = ttResults
.Where(row => !string.IsNullOrEmpty(row.RowMod) && row.RowMod != "P");
foreach (var ttResult in ttResultQuery)
var ds = new Erp.Tablesets.UpdExtSalesOrderTableset();
// Query to object mapping
var OrderDtl = new Erp.Tablesets.OrderDtlRow
Company = Constants.CurrentCompany,
NeedByDate = ttResult.OrderDtl_NeedByDate,
//OpenLine = ttResult.OrderDtl_OpenLine,
OrderLine = ttResult.OrderDtl_OrderLine,
OrderNum = ttResult.OrderDtl_OrderNum,
RequestDate = ttResult.OrderDtl_RequestDate,
ds.OrderDtl.Add(OrderDtl);
var OrderHed = new Erp.Tablesets.OrderHedRow
//CurrencyCode = ttResult.OrderHed_CurrencyCode,
//ExchangeRate = ttResult.OrderHed_ExchangeRate,
//NeedByDate = ttResult.OrderHed_NeedByDate,
//OrderAmt = ttResult.OrderHed_OrderAmt,
OrderNum = ttResult.OrderHed_OrderNum,
ds.OrderHed.Add(OrderHed);
BOUpdErrorTableset boUpdateErrors = updater.Update(ref ds);
if (this.BpmDataFormIsPublished()) return;
ttResult.RowMod = "P";
// Object to query mapping
var OrderDtl = ds.OrderDtl.FirstOrDefault(
tableRow => tableRow.Company == Constants.CurrentCompany
&& tableRow.OrderLine == ttResult.OrderDtl_OrderLine
&& tableRow.OrderNum == ttResult.OrderDtl_OrderNum);
if (OrderDtl == null)
OrderDtl = ds.OrderDtl.LastOrDefault();
var OrderHed = ds.OrderHed.FirstOrDefault(
&& tableRow.OrderNum == ttResult.OrderHed_OrderNum);
if (OrderHed == null)
OrderHed = ds.OrderHed.LastOrDefault();
if (OrderDtl != null)
ttResult.OrderDtl_NeedByDate = OrderDtl.NeedByDate;
//ttResult.OrderDtl_OpenLine = OrderDtl.OpenLine;
ttResult.OrderDtl_OrderLine = OrderDtl.OrderLine;
ttResult.OrderDtl_OrderNum = OrderDtl.OrderNum;
ttResult.OrderDtl_RequestDate = OrderDtl.RequestDate;
if (OrderHed != null)
//ttResult.OrderHed_CurrencyCode = OrderHed.CurrencyCode;
//ttResult.OrderHed_ExchangeRate = OrderHed.ExchangeRate;
//ttResult.OrderHed_NeedByDate = OrderHed.NeedByDate;
//ttResult.OrderHed_OrderAmt = OrderHed.OrderAmt;
ttResult.OrderHed_OrderNum = OrderHed.OrderNum;
if (boUpdateErrors?.BOUpdError?.Count > 0)
ttErrors
.AddRange(
boUpdateErrors.BOUpdError
.Select(
e => new ErrorsUbaqRow
TableName = e.TableName,
ErrorRowIdent = ttResult.RowIdent,
ErrorText = e.ErrorText,
ErrorType = e.ErrorType
var ttResultsForDelete = ttResults.Where(row => row.RowMod != "P").ToArray();
foreach (var ttResult in ttResultsForDelete){ ttResults.Remove(ttResult);}
foreach (var ttResult in ttResults){ ttResult.RowMod = "";}
Customer Update:
// <auto-generated>
using (var updater = this.getDataUpdater("Erp", "Customer"))
var Customer = new Erp.Tablesets.CustomerRow
Company = ttResult.Customer_Company,
CustNum = ttResult.Customer_CustNum,
Customer.SetUDField<System.String>("SiteID_c", ttResult.Customer_SiteID_c);
dsCustomer.Customer.Add(Customer);
BOUpdErrorTableset boUpdateErrorsCustomer = updater.Update(ref dsCustomer);
var Customer = dsCustomer.Customer.FirstOrDefault(
tableRow => tableRow.Company == ttResult.Customer_Company
&& tableRow.CustNum == ttResult.Customer_CustNum);
if (Customer == null)
Customer = dsCustomer.Customer.LastOrDefault();
if (Customer != null)
ttResult.Customer_Company = Customer.Company;
ttResult.Customer_CustNum = Customer.CustNum;
ttResult.Customer_SiteID_c = Customer.UDField<System.String>("SiteID_c", throwIfNull:false);
if (boUpdateErrorsCustomer?.BOUpdError?.Count > 0 )
ttErrors
.AddRange(
boUpdateErrorsCustomer.BOUpdError
.Select(
Then in the updated BAQ switched to the Advanced BPM update:
And then clicked on the BPM Directives Configuration and added two base processings and one custom code block under each that one of them contains the code for Customer Update and the other one for OrderDtl:
The problem is that after setting them up, although I do not get any error at any level, only the Base Processing that is order earlier (10,20,30,…) takes effect.
In other words, when I give the priority to Customer update, Customer table updates but OrderDtl does not, and when OrderDtl’s Base processing is prioritized, Customer table does not get updated…
I even tried clipping the last part of each code where the ttResult table gets cleared and see face this issue.
Just to emphasize UBAQ runs with no problem:
And after running, I get this:
