I created a updatable baq that is used on a dashboard that display job, operation and assembly info. This all works fine. I was then asked to add 3 UD fields (comment, Priority and Programmed)
the 3 fields must be updatable and is on the JobOper table.
The problem is that you cannot make any changes to the JobOper table if the job is released and Engineered . So in the BAQ under Updated I added a BPM directive that sets Engineered on the JobOper to false , I can then write the data and it works but i cannot set the engineered field back to true.
Do I need to change the order I do things in ? Any advice
@Anton_ALLtra I don’t know your company structure, but if it is not a deal breaker the changing an engineered job is a setting in company config under the production tab.
Another option if you are only updating UD fields is to make you own update. Here is the structure I got from Epicor.
