Receiving an unusual error. This error occurs if Maintenance Job Entry is open. Does not matter if I open with a current customization or a new base customization. Error occurs when right-clicking on the form not within a field. Error also occurs if right-clicking on another form not in the field (i.e. clicking in Employee form) This error only occurs if Maintenance Job Entry is open and the error message is the same whether clicking within the Maintenance Job Entry window or within another window.
Error occurs whether I am using a customization or if I create another base customization with nothing within.
Application Error
Exception caught in: Erp.UI.MaintJobEntry
Error Detail
Message: Object reference not set to an instance of an object.
Program: Erp.UI.MaintJobEntry.dll
Method: EpiContextToolsManager_AfterBuildContextMenu
Client Stack Trace
at Erp.UI.App.MaintJobEntry.MaintJobEntryForm.EpiContextToolsManager_AfterBuildContextMenu(Object sender, ContextToolEventArgs e)
at Ice.Lib.Framework.ContextToolHandler.Invoke(Object sender, ContextToolEventArgs e)
at Ice.Lib.Framework.EpiContextToolsManager.OnAfterBuildContextMenu(PopupMenuTool contextMenu, ContextMenuBinding contextBinding)
at Ice.Lib.Framework.PanelPopupMenuBuilder.BuildContextMenu(PopupMenuTool contextMenu, Control registeredControl, Control sourceControl)
at Ice.Lib.Framework.PopupMenuBuilderBase.BuildContextMenu(Control sourceControl)
at Ice.Lib.Framework.PopupMenuBuilderBase.ContextMenu_Opening(Object sender, CancelEventArgs e)
at System.Windows.Forms.ToolStripDropDown.OnOpening(CancelEventArgs e)
at System.Windows.Forms.ToolStripDropDown.SetVisibleCore(Boolean visible)
at System.Windows.Forms.ContextMenuStrip.SetVisibleCore(Boolean visible)
at System.Windows.Forms.ToolStripDropDown.Show(Control control, Point position)
at System.Windows.Forms.ContextMenuStrip.ShowInternal(Control source, Point location, Boolean isKeyboardActivated)
at System.Windows.Forms.Control.WmContextMenu(Message& m, Control sourceControl)
at System.Windows.Forms.Control.WmContextMenu(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
