Verify all customizations show passed for 700C. Verify any customization on labor manually by opening, doing test code to be sure it compiles and saving. I had one on that I did in 605 and would not verify, but would compile fine.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Sunday, November 04, 2012 10:32 AM
Subject: [Vantage] Unexpected error - see appserverlogs
Details of this:
Exception caught in: Epicor.Mfg.BO.Labor
See attachment.
We had no issues in our test environment and still don't. I tried on just my station, to copy that client folder to launch in Live. It did launch and did not produce the error. But it was pointing to the test server database. I updated the default.mfgsys file in the config folder to point to our current db but then when I launched it again, it produced the error again. I was really hoping to get this figured out today if anyone can help.
Otherwise, I do have a call into Epicor (did not go with weekend support as we had no real issues with the install of the test server). People can get into Epicor and run everything else normally as far as I know today, just can't labor transactions started or edited.
Melissa Hietala
UMC, Inc.
melissah@...<mailto:melissah%40ultramc.com>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg
Details of this:
See attachment.
Melissa Hietala
UMC, Inc.
