Steve,
This is what Mike and I worked out with your example..
End If
btnStart.Visible = True
dim rowsselected as boolean
Dim txtKeyField As String = edvUD07.dataView(edvUD07.Row)("Key2")
Dim UD21adapt As UD21Adapter = New UD21Adapter(UD07Form)
UD21adapt.BOConnect
dim rowswhereClause as string = "key1 = '" & txtKeyField & "'"
Dim dsUD21 As DataSet = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "UD21Adapter", rowsSelected, False, rowswhereClause)
ugdEpiCustom1.DataSource = dsUD21
For Each C as UltraGridColumn in ugdEpiCustom1.DisplayLayout.Bands(0).Columns
c.Hidden = TRUE
Next
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key3").Hidden = False
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key4").Hidden = False
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key5").Hidden = False
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Number02").Hidden = False
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key3").Header.Caption ="Part Number"
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key4").Header.Caption ="Job Number"
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Key5").Header.Caption ="Assembly"
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("Number02").Header.Caption ="Operation"
Thanks a bunch, works great!
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Thursday, June 09, 2011 10:46 AM
Subject: Re: [Vantage] unbound datagrid view - how to rename colums?
It looks like Yahoo really mangled my email. Let me know if you need any help on the syntax.
What I would really like to be able to do is to create a dataview that Vantage recognizes so I could use that to bind datagrids and controls to it. I've never been able to figure out how to do that.
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Sent: Thursday, June 9, 2011 10:40 AM
Subject: RE: [Vantage] unbound datagrid view - how to rename colums?
Thanks for the fast reply Steven! Ill play around with this and see what I can come up with.
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Steven Gotschall
Sent: Thursday, June 09, 2011 9:38 AM
You can either rename the column in the dataset or the Header Caption on the UltraGrid. Here is an example of both.
UD21adapt.BOConnect
dsUD21.Tables("UD21").Columns("UD21.Key1").ColumnName = "MyKey1Name"
c.Hidden - TRUE
Next
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("UD21.Key2").Hidden = FalseugdEpiCustom1.DisplayLayout.Bands(0).Columns("UD21.Key2").Header.Caption ="ThisIsKey2"
I haven't tested this particular code, but it should work if you get the column names right. I use something very similar in a couple of my customizations.
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> <mailto:rbucek%40dsmfg.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Thursday, June 9, 2011 10:14 AM
Subject: [Vantage] unbound datagrid view - how to rename colums?
Anyone know how to rename columns in an unbound data grid view? I have
a UD table coming in and only want 5 or 6 columns visible and assign a
specific column name. Right now, all columns come in with the original
column headers.. key1, key2 etc.. code thus far..
UD21adapt.BOConnect
Rob Bucek
FAX: (715)284-4084
ugdEpiCustom1.DisplayLayout.Bands(0).Columns("MyKey1Name").Hidden = False
End If
UD21adapt.BOConnect
c.Hidden = TRUE
Next
Rob Bucek
FAX: (715)284-4084
Rob Bucek
FAX: (715)284-4084
UD21adapt.BOConnect
c.Hidden - TRUE
Next
UD21adapt.BOConnect
Rob Bucek
FAX: (715)284-4084
