Here’s one I just did.
You know, I see that despite what the guide says, it’s grabbing the account from the vendor. Because that’s a different GL than the company one for me.
I think i’m closing in on the problem…
The WIP Recon shows these items being received via PackSlip 0066624
Yet there is no PackSlip 0066624
. But I did find a PackSlip 006624
(one less 6
) that is for the “same” items - but using P/N’s instead.
It looks like the order of things was:
- Sales Order created using On The Fly(OTF) P/N’s, marked to be BTO
- PO Created to buy those OTF items as BTO
- Receipt of PO against PackSlip 0066624
- New P/N’s created so those parts could be stocked.
- Order updated to use the system P/N’s instead of the OTF ones
- Pack Slip 0066624 was deleted
- PO Updated to use new P/N’s
- Pack Slip 006624 was created to recieve the items to stock under the New P/N’s
And somewhere in there, there was a hiccup. Probably because the P/N’s on the PO Lines were updated, but the underlying info about them being a BTO lines remained.
Well… I got one of the problems resolved. The solution to the first problem (PUR-UKN trans w/o offsetting accts) was resolved be re-openeing the PO Lines, and using the “Get Default GL acct” button on each release. The re-closing the PO. The WIP Recon report now balanced for those transactions.
The second problem comes from changing the P/N on an order.
- The order originally used an On The Fly (OTF) P/N (marked as BTO).
- Packer was created with the pack line referencing the OTF P/N. But not yet marked as shipped.
- The order line was changed to use a system part number (of a stocked item)
- The Packer was then marked as Shipped, which made a PartTran record of UKN-CUS
- The packer was invoiced.
There had never been a receipt for the OTF P/N. So no offsetting PUR-UKN record with a matching Part Number.
Unlike the first problem (where I could re-open the PO and tweak it), I cannot re-open the packer to fix it.
Well there are 2 ways to
fix this:
1. you need to identify at which posting rule it fails to get the
account. To do this easier do the following:
- clear the Posting engine log;
- run the report COS&WIP reconciliation report only for
PUR-UKN transaction, only on 30.03.2020 (the day you had the
problem);
- check in the posting engine log where it failed (you already
got there probably);
- expand the results to see why it is not getting the credit
account (because the debit side you already have, this is why your
transaction does not balance);
- go to GL transaction type, check the transaction type
“COSAndWIP” , see the active revision and expand it;
- go to the posting rule which fails. Fortunatelly there are
only 2 with PUR-UKN;
- probably what you need is the clearing account which cannot
be determined so you wil lfind a line like "Clearing account =
determine AP clearing account for parttran line ". This is a
function so right click on it and choose go to function
definition;
- the result is pretty simple to follow - account is determine
either from the Supplier AP Account GL control on the Clearing
context, or from Company AP account (also clearing account) or
Company inventory cos&WIP GL control (also clearing account).
The accounts are determined in this order.
- set the account on one of these depending on what your
accounting is saying (should it be on this supplier only, on all
suppliers or on all parts and all suppliers);
- run the report again.
2. quick and dirty solution - ignore these transactions for
posting. That is mark the part tran transactions as PostedtoGL=1
(instead of zero) and ask accouting to enter the transaction
manually directly in GL. This of course will create a problem if
you have any reports based on Tranglc table, will always show a GL
transaction entered manually into GL for stock accounts and you
will always have 4 lines in parttran without corresponding GL
booking.
I would however recommend option 1 (even if it might take you
about 2 hours to fix it) - this will also save you for having same
problem also next time when people do the same mistake.
Best regards,
Mihai
Mihai - Thanks for the detailed explanation. But I’ve already resolved the issue related to the bad PUR-UKN trans. I’m now onto the second problem transaction related to a UKN-CUS tran from a paker being shipped.
While it might appear that the UKN-CUS is related to the PUR-UKN, it is not. Just a coincidence, as the related items were for different orders.
Here’s a screen shot of the PE Log (actual text contents are below)
I’m pretty sure the yellow highlighted line is the issue. The green highlights were able to get the Acct
Details of the PE Log
COSAndWIP transaction type is processed for '' group in 'PostEditList' mode at '5/4/2020 10:07:58 AM'
Using Shared posting assembly 'COSANDWIP_MC_Post_114_Shared.cs'
Loading Document data. Group '' .Date '04/17/20'. VBD Version 5.0.
Loading Document data. Group '' .Date '4/17/2020 12:00:00 AM'. 1
Document line COSAndWIP has been created.
Post Entity has been added Details DataSource Key1 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Company DataSource Company Key1 MC Key2 Key3 Key4 Key5 Key6
Document line COSAndWIP--PartTran has been created.
Post Entity has been added Details DataSource PartTran Key1 04/17/20 Key2 35170 Key3 189863 Key4 Key5 Key6
Post Entity has been added Plant DataSource Plant Key1 HOUST Key2 Key3 Key4 Key5 Key6
Post Entity has been added Warehouse DataSource Warehse Key1 Hous Key2 Key3 Key4 Key5 Key6
Post Entity has been added Plant2 DataSource Plant Key1 HOUST Key2 Key3 Key4 Key5 Key6
Post Entity has been added Customer DataSource Customer Key1 3104 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Detail DataSource OrderDtl Key1 2200061 Key2 44 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Product Group DataSource ProdGrup Key1 F010 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Shipping Details DataSource ShipDtl Key1 32408 Key2 36 Key3 Key4 Key5 Key6
Post Entity has been added Details DataSource PartTran Key1 04/17/20 Key2 36151 Key3 189880 Key4 Key5 Key6
Post Entity has been added Part Class DataSource PartClass Key1 BTOP Key2 Key3 Key4 Key5 Key6
Post Entity has been added Customer DataSource Customer Key1 3604 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Detail DataSource OrderDtl Key1 2200269 Key2 1 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Product Group DataSource ProdGrup Key1 RECT Key2 Key3 Key4 Key5 Key6
Post Entity has been added Shipping Details DataSource ShipDtl Key1 32409 Key2 1 Key3 Key4 Key5 Key6
Post Entity has been added Purchase Order Release DataSource PORel Key1 49356 Key2 1 Key3 1 Key4 Key5 Key6
Post Entity has been added Details DataSource PartTran Key1 04/17/20 Key2 36698 Key3 189883 Key4 Key5 Key6
Post Entity has been added Customer DataSource Customer Key1 3598 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Detail DataSource OrderDtl Key1 2200213 Key2 1 Key3 Key4 Key5 Key6
Post Entity has been added Sales Order Product Group DataSource ProdGrup Key1 F005 Key2 Key3 Key4 Key5 Key6
Post Entity has been added Shipping Details DataSource ShipDtl Key1 32410 Key2 1 Key3 Key4 Key5 Key6
Post Entity has been added Purchase Order Release DataSource PORel Key1 49296 Key2 1 Key3 1 Key4 Key5 Key6
Post Entity has been added Details DataSource PartTran Key1 04/17/20 Key2 36698 Key3 189884 Key4 Key5 Key6
Post Entity has been added Sales Order Detail DataSource OrderDtl Key1 2200213 Key2 2 Key3 Key4 Key5 Key6
Post Entity has been added Shipping Details DataSource ShipDtl Key1 32410 Key2 2 Key3 Key4 Key5 Key6
Post Entity has been added Purchase Order Release DataSource PORel Key1 49296 Key2 2 Key3 1 Key4 Key5 Key6
Posting of Document line COSAndWIP
Loaded Document line data
Company entity posting codes
GL Has Inventory Interface =True
GLRef - Keys =MC
GLRef - PATH =Company--MC
GLRef - RTF =Company
Statutory Purchase Accounting =False
Details entity posting codes
Apply Date =04/17/20
GLRef - Keys =?
GLRef - RTF =?
Red Storno =False
Tran Date =?
Posting to V8 book
processing Header Rule rule. Version 3.
Getting Journal from GL Control COSAndWIP--Company--Inventory COS And WIP GL Control Type Inventory COS and WIP for context Inventory book V8 GLControlCode Reusable Entity GLRef Company|MC
Journal Code successfully retrieved IJ GLControlCode Default Reusable Entity GLRef Company|MC
1 line: Posting of Document line COSAndWIP--PartTran PartTran keys: Key1 04/17/20¯35170¯189863
Customer entity posting codes
Code =3104
GLRef - Keys =3104
GLRef - PATH =Customer--3104
GLRef - RTF =Customer
Is InterCompany =False
GLRef - Keys =04/17/20¯35170¯189863
GLRef - PATH =PartTran--04/17/20¯35170¯189863
GLRef - RTF =PartTran
Has Landed Cost =False
Is Reverted =False
Legal Number =32408
Tran Type =UKN-CUS
Use AR Clearing =True
Variance Target =
Plant entity posting codes
GLRef - Keys =HOUST
GLRef - PATH =Plant--HOUST
GLRef - RTF =Plant
Plant2 entity posting codes
GLRef - Keys =HOUST
GLRef - RTF =Plant
Sales Order Detail entity posting codes
GLRef - PATH =OrderDtl--2200061¯44
Sales Order Product Group entity posting codes
GLRef - Keys =F010
GLRef - PATH =ProdGrup--F010
GLRef - RTF =ProdGrup
Shipping Details entity posting codes
GLRef - PATH =ShipDtl--32408¯36
Warehouse entity posting codes
GLRef - Keys =Hous
GLRef - PATH =Warehse--Hous
GLRef - RTF =Warehse
Loaded Amount Extended Cost
Amount =2396.90
CalculationMethod =AVG
ConversionDate =04/17/20
Currency =USD
CurrencyType =Transactional
Name =Extended Cost
Loaded Amount Material Cost
Amount =2396.90
Currency =USD
Name =Material Cost
Posting to V8 book
Getting Journal from GL Control COSAndWIP--Company--Inventory COS And WIP GL Control Type Inventory COS and WIP for context Inventory book V8 GLControlCode Default Reusable Entity GLRef Company|MC
1 line: processing UKN-CUS/DRP-CUS/PUR-CUS: Post Extended Cost to Expense/AP Clearing and COS/AR Clearing Accounts rule. Version 5.
Select Amount Extended Cost
Select Name Extended Cost Amount Currency CurrencyType Transactional Calculationmethod ConversionDate
Amount has been found Extended Cost Value 2396.90 Currency USD CurrencyType Transactional
Getting account from GL Control COSAndWIP--PartTran--Purchase Order Release--GL Control Type PO Release for context Expense book V8 GLControlCode Reusable Sys(A) GLRef |
Unable to get account GLControlCode Reusable Sys(A) GLRef |
Getting account from GL Control COSAndWIP--Company--Inventory COS And WIP GL Control Type Inventory COS and WIP for context AR Clearing book V8 GLControlCode Default Reusable Entity GLRef Company|MC
Account successfully retrieved 1127|00|01 GLControlCode Default Reusable Entity GLRef Company|MC
Creation of Control Type PartTran
TranGLC created: GLControlType PartTranContext AR Clearing (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 35170 Key3 189863 Key4 Key5 Key6 GLAccount 1127|00|01
GLControl created with SequenceNum 1
Creating transaction --------------------------------------------------
Description Periodic Posting Process Transaction Date 4/17/2020 12:00:00 AM TranAmount 2396.90 USD BookAmount 2396.90 USD
Account 1127|00|01 IsDebit True Journal Line 1 Book V8
Creating transaction in UKN-CUS/DRP-CUS/PUR-CUS: Post Extended Cost to Expense/AP Clearing and COS/AR Clearing Accounts Rule
2 lines: Posting of Document line COSAndWIP--PartTran PartTran keys: Key1 04/17/20¯36151¯189880
Code =3604
GLRef - Keys =3604
GLRef - PATH =Customer--3604
GLRef - Keys =04/17/20¯36151¯189880
GLRef - PATH =PartTran--04/17/20¯36151¯189880
Is Reverted =False
Legal Number =32409
Tran Type =UKN-CUS
Variance Target =
Part Class entity posting codes
GLRef - Keys =BTOP
GLRef - PATH =PartClass--BTOP
GLRef - RTF =PartClass
Purchase Order Release entity posting codes
GLRef - Keys =49356¯1¯1
GLRef - PATH =PORel--49356¯1¯1
GLRef - RTF =PORel
Is Buy to Order =?
GLRef - PATH =OrderDtl--2200269¯1
GLRef - Keys =RECT
GLRef - PATH =ProdGrup--RECT
GLRef - PATH =ShipDtl--32409¯1
Amount =1599.00
Currency =USD
Name =Extended Cost
Amount =1599.00
Currency =USD
Name =Material Cost
Posting to V8 book
2 lines: processing UKN-CUS/DRP-CUS/PUR-CUS: Post Extended Cost to Expense/AP Clearing and COS/AR Clearing Accounts rule. Version 5.
Amount has been found Extended Cost Value 1599.00 Currency USD CurrencyType Transactional
Getting account from GL Control COSAndWIP--PartTran--Purchase Order Release--GL Control Type PO Release for context Expense book V8 GLControlCode 342359 Reusable Sys(A) GLRef PORel|49356¯1¯1
Account successfully retrieved 1166|00|01 GLControlCode 342359 Reusable Sys(A) GLRef PORel|49356¯1¯1
TranGLC created: GLControlType PartTranContext AR Clearing (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36151 Key3 189880 Key4 Key5 Key6 GLAccount 1127|00|01
GLControl created with SequenceNum 2
Description Periodic Posting Process Transaction Date 4/17/2020 12:00:00 AM TranAmount 1599.00 USD BookAmount 1599.00 USD
Account 1127|00|01 IsDebit True Journal Line 2 Book V8
TranGLC created: GLControlType PartTranContext Expense (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36151 Key3 189880 Key4 Key5 Key6 GLAccount 1166|00|01
GLControl created with SequenceNum 3
Account 1166|00|01 IsDebit False Journal Line 3 Book V8
2 lines: Posting of Document line COSAndWIP--PartTran PartTran keys: Key1 04/17/20¯36698¯189883
Code =3598
GLRef - Keys =3598
GLRef - PATH =Customer--3598
GLRef - Keys =04/17/20¯36698¯189883
GLRef - PATH =PartTran--04/17/20¯36698¯189883
Is Reverted =False
Legal Number =32410
Tran Type =UKN-CUS
Variance Target =
GLRef - Keys =BTOP
GLRef - Keys =49296¯1¯1
GLRef - PATH =PORel--49296¯1¯1
GLRef - RTF =PORel
Is Buy to Order =?
GLRef - PATH =OrderDtl--2200213¯1
GLRef - Keys =F005
GLRef - PATH =ProdGrup--F005
GLRef - PATH =ShipDtl--32410¯1
Amount =687.00
Currency =USD
Name =Extended Cost
Amount =687.00
Currency =USD
Name =Material Cost
Posting to V8 book
Amount has been found Extended Cost Value 687.00 Currency USD CurrencyType Transactional
Getting account from GL Control COSAndWIP--PartTran--Purchase Order Release--GL Control Type PO Release for context Expense book V8 GLControlCode 334801 Reusable Sys(A) GLRef PORel|49296¯1¯1
Account successfully retrieved 1166|00|01 GLControlCode 334801 Reusable Sys(A) GLRef PORel|49296¯1¯1
TranGLC created: GLControlType PartTranContext AR Clearing (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36698 Key3 189883 Key4 Key5 Key6 GLAccount 1127|00|01
GLControl created with SequenceNum 4
Description Periodic Posting Process Transaction Date 4/17/2020 12:00:00 AM TranAmount 687.00 USD BookAmount 687.00 USD
Account 1127|00|01 IsDebit True Journal Line 4 Book V8
TranGLC created: GLControlType PartTranContext Expense (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36698 Key3 189883 Key4 Key5 Key6 GLAccount 1166|00|01
GLControl created with SequenceNum 5
Account 1166|00|01 IsDebit False Journal Line 5 Book V8
2 lines: Posting of Document line COSAndWIP--PartTran PartTran keys: Key1 04/17/20¯36698¯189884
Code =3598
GLRef - Keys =3598
GLRef - Keys =04/17/20¯36698¯189884
GLRef - PATH =PartTran--04/17/20¯36698¯189884
Is Reverted =False
Legal Number =32410
Tran Type =UKN-CUS
Variance Target =
GLRef - Keys =BTOP
GLRef - Keys =49296¯2¯1
GLRef - PATH =PORel--49296¯2¯1
GLRef - RTF =PORel
Is Buy to Order =?
GLRef - PATH =OrderDtl--2200213¯2
GLRef - Keys =RECT
GLRef - PATH =ShipDtl--32410¯2
Amount =3299.00
Currency =USD
Name =Extended Cost
Amount =3299.00
Currency =USD
Name =Material Cost
Posting to V8 book
Amount has been found Extended Cost Value 3299.00 Currency USD CurrencyType Transactional
Getting account from GL Control COSAndWIP--PartTran--Purchase Order Release--GL Control Type PO Release for context Expense book V8 GLControlCode 334802 Reusable Sys(A) GLRef PORel|49296¯2¯1
Account successfully retrieved 1166|00|01 GLControlCode 334802 Reusable Sys(A) GLRef PORel|49296¯2¯1
TranGLC created: GLControlType PartTranContext AR Clearing (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36698 Key3 189884 Key4 Key5 Key6 GLAccount 1127|00|01
GLControl created with SequenceNum 6
Description Periodic Posting Process Transaction Date 4/17/2020 12:00:00 AM TranAmount 3299.00 USD BookAmount 3299.00 USD
Account 1127|00|01 IsDebit True Journal Line 6 Book V8
TranGLC created: GLControlType PartTranContext Expense (Ext Cost)RelatedToFile = PartTran Key1 04/17/20 Key2 36698 Key3 189884 Key4 Key5 Key6 GLAccount 1166|00|01
GLControl created with SequenceNum 7
Account 1166|00|01 IsDebit False Journal Line 7 Book V8
Book related errors: Transaction does not balance book: V8
Book related warnings: Fiscal Period is closed BookID V8. FiscalCalendarID V8. FiscalYear 2020. FiscalYearSuffix . FiscalPeriod 4. book: V8
ReviewJournal 1 bookV8 valid False
For the record, whenever a GL Account is missing or wrong, it is always associated with a GL Control Code either being missing or wrong. In the case where you are using GL Controls for Depts, Divisions, Category Codes, etc, the issue is usually that the calculated GL Account string may not exist.
I find no documentation for an UKN-CUS transaction.
Supports solution was to provide me a data fix that changed the TranType from UKN-CUS
to STK-CUS
. Even though the parttran record still references an non existent partnumber.
