Hi,
We are processing time and expense entries for jobs via DMT. We report quantity only for limited items via MES.
So we made a mistake on a job (used wrong part number) and need to uncomplete the operations on that job. But when I try to undo the transactions via DMT or in Time & Expense Entry, I get "Invalid to modify a transaction that has been Submitted for Approval."
I don't seem to have the Time & Expense module installed. The Time & Expense Entry from Job Management has the fields all greyed out on the Daily Time Detail sheet.
How do I go about unapproving the entries?
Joe
Joe D. Trent
Bigham Ag Equipment
>>How do I go about unapproving the entriesHave you tries Epicor tech?
They provided an updateable dashboard for editing labordtl records.
Not exactly like what you describe but it sounds related
I routinely use the dashboard to clean labordtl status.
In my case, can't close jobs until all labordtl records status = "A" (Approved).
We use an updateable BAQ
Brenda
Sent: Thursday, August 27, 2015 1:53 PM
Subject: [Vantage] Re: Unapprove Time & Expense Transaction
E10, btw.
>>Epicor Supplied Updateable BAQYou can check the files section here too
Files --> BAQ --> LaborUpdate.baq
Maybe try it in a test system first but...
It should work for you, just adjust the criteria first
Nope, but we’ve been using it for 4 yrs (9&10) w/ no “known†side effects. We just use it to change the status on rare occasions.
Brenda
Sent: Thursday, August 27, 2015 3:57 PM
Subject: RE: [Vantage] Re: Unapprove Time & Expense Transaction
Brenda,
Was that Epicor Support supplied.
Joe
