"Un-completing" an operation for a job
Thanks for the tip, but the receipt has already been invoiced. Can't edit
the receipt.
Keith
Sent: Tuesday, August 28, 2001 9:14 AM
To: kauspland@...
Subject: RE: [Vantage] "Un-completing" an operation for a job
Was the first 5000 received from the finisher and marked as complete in
receipt entry before the 2nd 5000 were ready to go out? Would editting the
receipt reopen the operation? We also add extra operations to handle rejects
going back to the finishers.
Dan Shallbetter
States Electric Mfg.
Sent: Tuesday, August 28, 2001 11:56 AM
To: 'vantage@yahoogroups.com'
Hi Keith,
Like Cameron said, because occasionally this happens to us. I would
create a subc operation 41 that re-creates along with the comments the
same as op 40. At least you won't have to create a whole new job.
Dan Clifton
Northwest Swiss-Matic
Sent: 8/28/01 1:39 PM
Importance: High
Thanks Warren,
That was the first thing we tried. However, this is not a Labor entry.
It
is accomplished when the P.O. is made for the plating process, and my
shipper ships the parts to plater in Vantage.
Keith O. Auspland
Production Coordinator
Lovejoy Chaplet Corporation
12 River Street, P.O. Box 66
Hoosick falls, NY 12090
PHONE (802) 686-5232
FAX (802) 686-4919
Kauspland@...
Sent: Tuesday, August 28, 2001 7:17 AM
To: kauspland@...
When we have this happen we locate (in Job Tracker) the "operator" or
employee that entered labor with "job complete". We remove the complete
status in labor entry.
Hope this helps.
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
Phone: (219) 478-2363 ext 217
Fax: (219) 478-1043
Warren.Eddy@...
Sent: Tuesday, August 28, 2001 9:10 AM
Subject: [Vantage] "Un-completing" an operation for a job
Hello All.
I have a job set up in Vantage, with the following operations:
Op 10 = set-up process
Op 20 = manufacturing process
Op 30 = Inspection Process
Op 40 = Sub-contractor plating process
Op 50 = Final Inspection Process prior to shipment to customer
Now, I have a job set up for 10,000 pcs. 5,000 pcs were shipped last
week to our subcontractor. Now my shippind department wants to ship
the balance to our plater, but on that specific job, Operation 40
shows as complete. I have tried to no avail to "un-complete" this
operation. When I try to generate a P.O. for my plater and refer to
this specific job, there is nothing left to "pull" from Operation 40,
and op 40 shows as complete.
I have tried numerous different strategies to "un-complete" Op 40,
but all to no avail.... As an "end-around," I generated a new job for
the remaining 5,000 pcs, created the P.O., shipped the parts, then
immediately closed the job. This is not the correct way to
accomplish this, but I HAD to ship parts...
Anyone with any assistance, it would be GREATLY appreciated...
Thanks In Advance
Keith
have
and
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
have
and
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=210949.1523302.3121208.1269402/D=egroupweb/S=17050071
83:HM/A=763786/R=0/*http://altfarm.mediaplex.com/ad/ck/1177-4458-1039-1?mpt=
999014415>
<http://us.adserver.yahoo.com/l?M=210949.1523302.3121208.1269402/D=egroupmai
l/S=1705007183:HM/A=763786/rand=374891558>
Hello All.
Thanks In Advance
Keith
Hope this helps.
Warren R. Eddy
Fax: (219) 478-1043
Warren.Eddy@...
Hello All.
Thanks In Advance
Keith
You could have created Op 45 = Sub-contractor plating process. This should
give you a place to pull the remaining pieces from.
Sent: Tuesday, August 28, 2001 07:10 AM
Hello All.
Thanks In Advance
Keith
ADVERTISEMENT
You can, too! Start here...
Height:
3 4 5 6 7 8 ft 0 1 2 3 4 5 6 7 8 9 10 11 in
Weight:
lbs. kg.
Thanks Warren,
That was the first thing we tried. However, this is not a Labor entry. It
Keith O. Auspland
FAX (802) 686-4919
Kauspland@...
To: kauspland@...
Hope this helps.
Warren R. Eddy
Fax: (219) 478-1043
Warren.Eddy@...
Hello All.
Thanks In Advance
Keith
Hi Keith,
Dan Clifton
Importance: High
Thanks Warren,
It
Keith O. Auspland
FAX (802) 686-4919
Kauspland@...
To: kauspland@...
Hope this helps.
Warren R. Eddy
Fax: (219) 478-1043
Warren.Eddy@...
Hello All.
Thanks In Advance
Keith
have
and
have
and
Keith,
Did you check the receipt that was entered for the Subcontract operation?
This is usually where the operation is flagged complete. There are two
things that could be flagged complete when entering the receipt. The first
is if it is "received complete" which is linked up to the PO and the second
is "issued complete" which is linked back to the job. HTH.
Jim
> From: Dan Clifton [mailto:dclifton@...]
> Hi Keith,
> Dan Clifton
> From: Keith Auspland [mailto:kauspland@...]
> Importance: High
> Thanks Warren,
> It
> Keith O. Auspland
> FAX (802) 686-4919
> Kauspland@...
> From: Eddy, Warren [mailto:warren.eddy@...]
> To: kauspland@...
> Hope this helps.
> Warren R. Eddy
> Fax: (219) 478-1043
> Warren.Eddy@...
> From: kauspland@... [mailto:kauspland@...]
> Hello All.
> Thanks In Advance
> Keith
> have
> and
> have
> and
> must have already linked your email address to a yahoo id to
> enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
Dan Shallbetter
Hi Keith,
Dan Clifton
Importance: High
Thanks Warren,
It
Keith O. Auspland
FAX (802) 686-4919
Kauspland@...
To: kauspland@...
Hope this helps.
Warren R. Eddy
Fax: (219) 478-1043
Warren.Eddy@...
Hello All.
Thanks In Advance
Keith
have
and
have
and
999014415>
