UltraGrid/User Defined Tables
Not necessarily, we're apparently being trained in the use of PC in a
months time. I've had a quick demo of what it can do and it certianly
looks good, so I might just wait till then.
Bill
--- In vantage@yahoogroups.com, "Debbie Stokes" <debbie.stokes@...>
wrote:
> You could try product configurator if you have that option or is
this a
> sledgehammer to crack a nut ?
> kind regards
> Debbie Stokes
> Vantage Administrator
> Hilo-PSS Group
> 01793 647136
> This email is intended for the addressee only and may contain
information that is privileged and confidential. If you are not the
intended recipient, you must not copy, distribute or take any
> action in reliance on it. If this email has been sent to you in
error, please notify us immediately by telephone.
> This has been transmitted by -
> Hilo-PSS Group
> Murdock Road
> Dorcan Industrial Estate
> Swindon
> SN3 5HY
> Company Registration No: 01028915.
> The views within this email are those of the author and not
> necessarily those of Planned Storage Systems Ltd.
> ** This email has been scanned for viruses, vandals and malicious
content **
Hi - I'm fairly new to working with Vantage but I've been developing
with a variety of tools over the years. I have a question regarding
form customization which I'm hoping someone may be able to help with:
I need to add in additional fields to the Order Entry screen to cater
for product specifications - these are basically varying product
dimensions and for each order there could be any number of variations.
I also need to be able to pull that data through to the job entry.
I first thought of using the custom fields until I found I'm limited to
about 20 numeric fields - I will potentially need far more than 20. So
I then thought I could use a user defined table, create the fields I
need and access that in the original order form by way of an ultragrid.
So I've created the new table and then go to the order form, drag in a
grid control and try to set the data source, but I don't see my user
defined table listed. Is there a reason for this, and can someone
suggest a better approach to what I'm trying to do ?
Thx
WM
You could try product configurator if you have that option or is this a
kind regards
Debbie Stokes
Hilo-PSS Group
01793 647136
This email is intended for the addressee only and may contain information that is privileged and confidential. If you are not the intended recipient, you must not copy, distribute or take any
action in reliance on it. If this email has been sent to you in error, please notify us immediately by telephone.
Hilo-PSS Group
Murdock Road
Swindon
SN3 5HY
** This email has been scanned for viruses, vandals and malicious content **
