Ultra Grid / User Defined Tables
Perfect, Thanks!
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Try this:
> Dim recSelected As Boolean
> Dim whereClause As String = String.Empty
> Dim YourVariable As DataSet =
> Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
> "UD01Adapter", recSelected, False, whereClause)
> If (recSelected) Then
> ugdYourUltraGrid.DataSource = YourVariable
> End If
> You will have to change your adapter in the listlookup string, modify your
> variable names and change your whereclause if you want a filter.
> HTH,
> Ross
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> batlou
> Sent: Tuesday, January 12, 2010 9:38 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Ultra Grid / User Defined Tables
> Is it possible to attach a grid to a UD table? I have used these tables for
> other field types but cant seem to figure out how to use the retriever on a
> grid.
> Help?
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Is it possible to attach a grid to a UD table? I have used these tables for other field types but cant seem to figure out how to use the retriever on a grid.
Help?
Try this:
End If
HTH,
Ross
batlou
grid.
Help?
