Any documents anywhere on an example to how to use one of these?
~Charlie
_____
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Rob Bucek
Sent: Tuesday, September 29, 2009 9:48 AM
To:
Subject: RE: [Vantage] Reason Code Customization Filter
In customization look under tools/object explorer expand the controls
node.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
http://www.dsmfg <
http://www.dsmfg.com/> com/>
(Click the logo to view our site) <
http://www.dsmfg <
com/>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Tuesday, September 29, 2009 7:35 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Where are the VB methods and properties for ultracombo controls I'm not
familiar with those.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Robert Brown
Sent: Friday, September 25, 2009 3:38 AM
Subject: Re: [Vantage] Reason Code Customization Filter
Charlie
You probably aren't missing anything. (Once again - being 3am and only
awake
because of a back problem that refuses to allow me to sleep tonight -
I'm
not connected to work so I can't check if ultracombos support the filter
property.)
In customization mode, check the VB methods and properties for
ultracombo
controls. You may get lucky and find it is only the brain dead
development
environment properties window that is not showing you the filter
property.
If true, you can hard set it with an appropriate variation of the code
example listed for the control property (if it indeed exists for
ultracombos).
If no luck there, worst case might be to simply add display of the
partrev.approved checkbox to the app. You don't say what app you are
customizing so this table.column may or may not be within one of the
native
views. If it is, it is a snap to do. If it isn't, add it as an FKV (or
do
your own search by ID lookup with VB code).
Rob
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com>
Sent: Tuesday, September 22, 2009 7:21:59 AM
The search filter option seems to be available on a combo box but not an
ultracombo. Am I missing something?
~Charlie
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of
Robert Brown
Sent: Tuesday, September 22, 2009 6:37 AM
To: vantage@yahoogroups .com
In the properties window for your added control, one of the properties
in
the top section (I'm not connected to Vantage so I can't tell you its
specific title) that allows you to effectively specify a filter such as
you
describe.
I think if you look at most any editing app that pulls in
PartRev.Revision,
you'll see an example of it where some of the native Rev controls in
various
apps are filtered to only allow PartRev.Approved= True revisions to
appear
in
the pulldown.
(There may be other examples - like limits on Part where Inactive is
False).
Snoop around and you'll find a model to follow for what you want to do
with
the reason code type.
Perhaps someone connected to Vantage can give you the control property
line
name where you can enter your filter criteria.
Not enough java in me yet to jog my brain fully awake & I'm drawing a
blank.
(;o
Rob
____________ _________ _________ __
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesignc sw%40yahoo.
com>
yahoo.com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Sent: Monday, September 21, 2009 11:47:47 AM
Subject: [Vantage] Reason Code Customization Filter
I have added an Ultra Combo Box to a screen that is a drop down from the
Reason table. I would like to filter the options that show up in the
combo
box by the Reason.ReasonType field. How can I do this The standard
options
don't really seem to have a filter option any advice?
~Charlie
