I am trying to configure and enable the UK CSF capabilities on my Epicor 10.2.300.10 platform (actually to the point where I created a simple 10.2.300.0 app stack to see if it was a problem with .10), and I keep getting the error:
System.AggregateException: One or more errors occurred. —> System.IO.FileNotFoundException: Could not load file or assembly ‘Microsoft.SqlServer.BatchParser.dll’ or one of its dependencies. The specified module could not be found.
at System.Reflection.RuntimeAssembly.GetType(RuntimeAssembly assembly, String name, Boolean throwOnError, Boolean ignoreCase, ObjectHandleOnStack type)
at System.Reflection.RuntimeAssembly.GetType(String name, Boolean throwOnError, Boolean ignoreCase)
at System.Reflection.Assembly.GetType(String name, Boolean throwOnError)
at Microsoft.SqlServer.Management.Common.ServerConnection.GetStatements(String query, ExecutionTypes executionType, Int32& statementsToReverse)
at Microsoft.SqlServer.Management.Common.ServerConnection.ExecuteNonQuery(String sqlCommand, ExecutionTypes executionType, Boolean retry)
at Ice.Tools.DatabaseScriptRunner.TreeNodeSqlScript.RunBatchScript(SqlConnection connection, String script)
at Ice.Tools.DatabaseScriptRunner.TreeNodeSqlScript.<>c__DisplayClass12_0.b__0()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
— End of inner exception stack trace —
(Inner Exception #0) System.IO.FileNotFoundException: Could not load file or assembly ‘Microsoft.SqlServer.BatchParser.dll’ or one of its dependencies. The specified module could not be found.
File name: ‘Microsoft.SqlServer.BatchParser.dll’
When I go into Epicor Admin Console to Run Database Script Runner after installing the solution found in the UK CSF zip file (Epicor_CSF_UK_Prep_10.2.300.cab). I have already enabled the UK option under the CSF tab in the license file. I have also gone into Epicor and ensured the Company Config steps were done as well. I am following the Epicor ERP UK CSF Guide for 10.2.300.
I have tried installing Visual Studios 2015 and 2017 to get a 64 bit version of the BatchParser.dll file in my \Windows\Assembly directory, per Internet suggestions. No 64-bit version, same error. Maybe I am not installing the correct item.
My Epicor 10.2 framework is installed on a Windows Server 2016 server, my MS SQL is on it’s own Windows Server 2016 machine with MSSQL 2016 SP2, and I have a third server for RDS. I am running the client for following the CSF instructions off the App server, not the RDS server.
Has anyone else ever experienced this? Or anything like this? Any ideas on how to proceed? Thanks,
David
