Hi All,
I’m trying to use UD40 Maintenance to create a new Entry Screen.
I have added the columns to the UD Extended Maintenance for UD40. I was getting duplication errors as followed
so I assigned ReworkNum_c to Key5 but now I’m getting this, stuck on "Getting New…
Here is my code:
// Custom code for UD40Form
// Created: 08/02/2021 11:58:41
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
private UD40Adapter _ud40Adapter;
private EpiDataView _edvUD40;
private DataTable ReworkUD40_Column;
private string _Key1UD40;
private string _Key2UD40;
private string _Key3UD40;
private string _Key4UD40;
private string _Key5UD40;
private DataView UD40_DataView;
InitializeUD40Adapter();
this._Key1UD40 = string.Empty;
this._Key2UD40 = string.Empty;
this._Key3UD40 = string.Empty;
this._Key4UD40 = string.Empty;
this._Key5UD40 = string.Empty;
this.baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD40);
this.UD40Form.BeforeToolClick += new Ice.Lib.Framework.BeforeToolClickEventHandler(this.UD40Form_BeforeToolClickForUD40);
this.UD40Form.AfterToolClick += new Ice.Lib.Framework.AfterToolClickEventHandler(this.UD40Form_AfterToolClickForUD40);
this.UD40_Row.EpiRowChanged += new EpiRowChanged(this.UD40_AfterRowChangeForUD40);
this.UD40_DataView = this.UD40_Row.dataView;
this.UD40_DataView.ListChanged += new ListChangedEventHandler(this.UD40_DataView_ListChangedForUD40);
this.UD40_Row.BeforeResetDataView += new Ice.Lib.Framework.EpiDataView.BeforeResetDataViewDelegate(this.UD40_BeforeResetDataViewForUD40);
this.UD40_Row.AfterResetDataView += new Ice.Lib.Framework.EpiDataView.AfterResetDataViewDelegate(this.UD40_AfterResetDataViewForUD40);
if ((this._ud40Adapter != null))
this._ud40Adapter.Dispose();
this._ud40Adapter = null;
this._edvUD40 = null;
this.UD40_Column = null;
this._Key1UD40 = null;
this._Key2UD40 = null;
this._Key3UD40 = null;
this._Key4UD40 = null;
this._Key5UD40 = null;
this.baseToolbarsManager.ToolClick -= new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD40);
this.UD40Form.BeforeToolClick -= new Ice.Lib.Framework.BeforeToolClickEventHandler(this.UD40Form_BeforeToolClickForUD40);
this.UD40Form.AfterToolClick -= new Ice.Lib.Framework.AfterToolClickEventHandler(this.UD40Form_AfterToolClickForUD40);
this.UD40_Row.EpiRowChanged -= new EpiRowChanged(this.UD40_AfterRowChangeForUD40);
this.UD40_DataView.ListChanged -= new ListChangedEventHandler(this.UD40_DataView_ListChangedForUD40);
this.UD40_DataView = null;
this.UD40_Row.BeforeResetDataView -= new Ice.Lib.Framework.EpiDataView.BeforeResetDataViewDelegate(this.UD40_BeforeResetDataViewForUD40);
this.UD40_Row.AfterResetDataView -= new Ice.Lib.Framework.EpiDataView.AfterResetDataViewDelegate(this.UD40_AfterResetDataViewForUD40);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void InitializeUD40Adapter()
// Create an instance of the Adapter.
this._ud40Adapter = new UD40Adapter(this.oTrans);
this._ud40Adapter.BOConnect();
// Add Adapter Table to List of Views
// This allows you to bind controls to the custom UD Table
this._edvUD40 = new EpiDataView();
this._edvUD40.dataView = new DataView(this._ud40Adapter.UD40Data.UD40);
this._edvUD40.AddEnabled = true;
this._edvUD40.AddText = "New UD40";
if ((this.oTrans.EpiDataViews.ContainsKey("UD40View") == false))
this.oTrans.Add("UD40View", this._edvUD40);
// Initialize DataTable variable
this.UD40_Column = this._ud40Adapter.UD40Data.UD40;
// Initialize EpiDataView field.
this._edvUD40 = ((EpiDataView)(this.oTrans.EpiDataViews["UD40"]));
// Set the parent view / keys for UD child view
string[] parentKeyFields = new string[1];
string[] childKeyFields = new string[1];
parentKeyFields[0] = "ReworkNum_c";
childKeyFields[0] = "Key5";
this._edvUD40.SetParentView(this._edvUD40, parentKeyFields, childKeyFields);
if ((this.oTrans.PrimaryAdapter != null))
// this.oTrans.PrimaryAdapter.GetCurrentDataSet(Ice.Lib.Searches.DataSetMode.RowsDataSet).Tables.Add(this._edvUD40.dataView.Table.Clone())
private void GetUD40Data(string key1, string key2, string key3, string key4, string key5)
if ((this._Key1UD40 != key1) || (this._Key2UD40 != key2) || (this._Key3UD40 != key3) || (this._Key4UD40 != key4) || (this._Key5UD40 != key5))
// Build where clause for search.
string whereClause = "Key1 = \'" + key1 + "\' And Key2 = \'" + key2 + "\' And Key3 = \'" + key3 + "\' And Key4 = \'" + key4 + "\'";
System.Collections.Hashtable whereClauses = new System.Collections.Hashtable(1);
whereClauses.Add("UD40", whereClause);
// Call the adapter search.
SearchOptions searchOptions = SearchOptions.CreateRuntimeSearch(whereClauses, DataSetMode.RowsDataSet);
this._ud40Adapter.InvokeSearch(searchOptions);
if ((this._ud40Adapter.UD40Data.UD40.Rows.Count > 0))
this._edvUD40.Row = 0;
} else
this._edvUD40.Row = -1;
// Notify that data was updated.
this._edvUD40.Notify(new EpiNotifyArgs(this.oTrans, this._edvUD40.Row, this._edvUD40.Column));
// Set key fields to their new values.
this._Key1UD40 = key1;
this._Key2UD40 = key2;
this._Key3UD40 = key3;
this._Key4UD40 = key4;
this._Key5UD40 = key5;
private void GetNewUD40Record()
DataRow parentViewRow = this._edvUD40.CurrentDataRow;
// Check for existence of Parent Row.
if ((parentViewRow == null))
return;
if (this._ud40Adapter.GetaNewUD40())
string reworknum_c = parentViewRow["ReworkNum_c"].ToString();
// Get unique row count id for Key5
int rowCount = this._ud40Adapter.UD40Data.UD40.Rows.Count;
int lineNum = rowCount;
bool goodIndex = false;
while ((goodIndex == false))
// Check to see if index exists
DataRow[] matchingRows = this._ud40Adapter.UD40Data.UD40.Select("Key5 = \'" + lineNum.ToString() + "\'");
if ((matchingRows.Length > 0))
lineNum = (lineNum + 1);
} else
goodIndex = true;
// Set initial UD Key values
DataRow editRow = this._ud40Adapter.UD40Data.UD40.Rows[(rowCount - 1)];
editRow.BeginEdit();
editRow["Key1"] = reworknum_c;
editRow["Key2"] = string.Empty;
editRow["Key3"] = string.Empty;
editRow["Key4"] = string.Empty;
editRow["Key5"] = lineNum.ToString();
editRow.EndEdit();
this._edvUD40.Notify(new EpiNotifyArgs(this.oTrans, (rowCount - 1), this._edvUD40.Column));
private void SaveUD40Record()
// Save adapter data
this._ud40Adapter.Update();
private void DeleteUD40Record()
// Check to see if deleted view is ancestor view
bool isAncestorView = false;
Ice.Lib.Framework.EpiDataView parView = this._edvUD40.ParentView;
while ((parView != null))
if ((this.oTrans.LastView == parView))
isAncestorView = true;
break;
} else
parView = parView.ParentView;
// If Ancestor View then delete all child rows
if (isAncestorView)
DataRow[] drsDeleted = this._ud40Adapter.UD40Data.UD40.Select("Key1 = \'" + this._Key1UD40 + "\' AND Key2 = \'" + this._Key2UD40 + "\' AND Key3 = \'" + this._Key3UD40 + "\' AND Key4 = \'" + this._Key4UD40 + "\'");
for (int i = 0; (i < drsDeleted.Length); i = (i + 1))
this._ud40Adapter.Delete(drsDeleted[i]);
} else
if ((this.oTrans.LastView == this._edvUD40))
if ((this._edvUD40.Row >= 0))
DataRow drDeleted = ((DataRow)(this._ud40Adapter.UD40Data.UD40.Rows[this._edvUD40.Row]));
if ((drDeleted != null))
if (this._ud40Adapter.Delete(drDeleted))
if ((_edvUD40.Row > 0))
_edvUD40.Row = (_edvUD40.Row - 1);
private void UndoUD40Changes()
this._ud40Adapter.UD40Data.RejectChanges();
private void ClearUD40Data()
this._ud40Adapter.UD40Data.Clear();
private void baseToolbarsManager_ToolClickForUD40(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
// EpiMessageBox.Show(args.Tool.Key);
switch (args.Tool.Key)
case "EpiAddNewNew UD40":
GetNewUD40Record();
break;
case "ClearTool":
ClearUD40Data();
break;
case "UndoTool":
UndoUD40Changes();
break;
private void UD40Form_BeforeToolClickForUD40(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
case "SaveTool":
SaveUD40Record();
break;
private void UD40Form_AfterToolClickForUD40(object sender, Ice.Lib.Framework.AfterToolClickEventArgs args)
case "DeleteTool":
if ((args.Cancelled == false))
DeleteUD40Record();
break;
private void UD40_AfterRowChangeForUD40(EpiRowChangedArgs args)
// ** add AfterRowChange event handler
string reworknum_c = args.CurrentView.dataView[args.CurrentRow]["ReworkNum_c"].ToString();
GetUD40Data(reworknum_c, string.Empty, string.Empty, string.Empty, string.Empty);
private void UD40_DataView_ListChangedForUD40(object sender, ListChangedEventArgs args)
// ** add ListChanged event handler
string reworknum_c = UD40_DataView[0]["ReworkNum_c"].ToString();
private void UD40_BeforeResetDataViewForUD40(object sender, EventArgs args)
// ** remove ListChanged event handler
private void UD40_AfterResetDataViewForUD40(object sender, EventArgs args)
// ** reassign DataView and add ListChanged event handler
Thank you
Aaron.
