UD Table not showing
I used UD35 to create a table and need to display on the another entry screen. I am can set it up fine using the EpiComb box but when I go to select the EpiBOname it doesn’t show beyond UD20 in the list. Is this a bug?
Looks like a bug in Epicor 9 and 10
Epicor Response:
I did check E9.05.702a and did re-create the reported issue.
I searched to see if the issue has already been reported and it was not, so I ran a Test in the current Epicor Release (10.1.600.9). Since I was also able to re-create the issue in the current Epicor release, I submitted the Problem to Development for E10.1.600.9.
I tested the baseline Epicor 10.1.600.9 software and duplicated the problem. Since this is no longer a Support Issue, but now a Development Problem, I created a New, Development Problem Case.
The Problem Case Number is PRB0187838 and has the following Description:
PROBLEM DESCRIPTION: When an EpiCombo is added to a form and then the EpiBOName Property in the EpiCombo section is selected, the drop down list does not include all UDxx tables. In other words, the Data Dictionary Viewer lists UD Tables UD01 to UD40, however, the EpiBOName drop down only lists UD tables UD01 to UD20.
EXPECTED BEHAVIOR: Since UD tables UD01 to UD40 are defined, the EpiBOName drop down list should include UD tables UD01 to UD40.
