Dear experts, How to add custom QuickPrintPreview button in standard tool bar using UD01 form?
Step 1
using Infragistics.Win.UltraWinToolbars;
Step 2
private void UD01Form_Load(object sender, EventArgs args)
ButtonTool btnPrintTool = new ButtonTool("MyPrintTool");
//Set the properties
btnPrintTool.SharedProps.Caption = "Print List";
btnPrintTool.SharedProps.Enabled = true;
btnPrintTool.SharedProps.Visible = true;
btnPrintTool.SharedProps.AppearancesSmall.Appearance.Image = EpiUIImages.SmallEnabledImages.Images[EpiUIImages.IndexOf("Print")];
btnPrintTool.ToolClick += new ToolClickEventHandler(btnPrintTool_ToolClick);
baseToolbarsManager.Tools.Add(btnPrintTool);
baseToolbarsManager.Toolbars["Standard Tools"].Tools.AddTool("MyPrintTool");
private void btnPrintTool_ToolClick(object sender,ToolClickEventArgs args)
EpiMessageBox.Show("Printed Successfully");
The UD Form actually comes with the regular Print Tool, it doesnt do anything but you can make it visible and then use it.
// Enable the Print Tool
baseToolbarsManager.Tools["PrintTool"].SharedProps.Enabled = true;
baseToolbarsManager.Tools["PrintTool"].SharedProps.Visible = true;
Then just use the event
private void UD100Form_BeforeToolClick(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
switch (args.Tool.Key)
case "PrintTool":
if (edvUD100A.dataView.Count == 0) {
args.Handled = true;
break;
Thats another option. I do appreciate @surendrapal solution. Good timing as I just needed to add a new button to the Standard Tools
Also just for the sake of snippets… You can also add a Dropdown to the Standard Tools and some other stuff.
private void SetupToolbarItems()
// Get The Main Toolbar
UltraToolbar mainToolBar = this.baseToolbarsManager.Toolbars["Standard Tools"];
// Remove the Single NewTool Button from the Toolbar Root
mainToolBar.Tools.Remove(mainToolBar.Tools["NewTool"]);
// Make Epicors Popup Tool NewMenuTool Visibile (most forms have this hidden by default)
baseToolbarsManager.Tools["NewMenuTool"].SharedProps.Visible = true;
// Hide the Save Button since we will not allow Saving
baseToolbarsManager.Tools["SaveTool"].SharedProps.Visible = false;
// Hide the Delete Tool since will not allow Deleting
baseToolbarsManager.Tools["DeleteTool"].SharedProps.Visible = false;
// Hide the Search Tool since we will not allow Searching
baseToolbarsManager.Tools["SearchTool"].SharedProps.Visible = false;
// Make others Visible or Invisible
// Remove these Items from the Toolbar but not from the Actions Menu
string[] arMainTools = new string[6] {"CutTool", "RefreshTool", "CopyTool", "PasteTool", "UndoTool", "AttachmentTool"};
foreach (string tool in arMainTools)
mainToolBar.Tools.Remove(mainToolBar.Tools[ tool ]);
// WIP: Skids
Infragistics.Win.UltraWinToolbars.ComboBoxTool comboSkidCountTool = new Infragistics.Win.UltraWinToolbars.ComboBoxTool("SkidCount");
Infragistics.Win.UltraWinToolbars.LabelTool skidToolLbl = new Infragistics.Win.UltraWinToolbars.LabelTool("SkidCountLabel");
skidToolLbl.SharedProps.Caption = "Skids: ";
skidToolLbl.SharedProps.AppearancesSmall.Appearance.TextHAlign = Infragistics.Win.HAlign.Right;
skidToolLbl.SharedProps.MinWidth = 50;
skidToolLbl.SharedProps.Width = 50;
skidToolLbl.SharedProps.MaxWidth = 50;
// Show 32 Skids
for (int i = 1; i < 33; i++)
comboSkidCountTool.ValueList.ValueListItems.Add( i );
comboSkidCountTool.SharedProps.MinWidth = 40;
comboSkidCountTool.SharedProps.Width = 40;
comboSkidCountTool.SharedProps.MaxWidth = 40;
comboSkidCountTool.SharedProps.AppearancesSmall.Appearance.TextHAlign = Infragistics.Win.HAlign.Left;
comboSkidCountTool.SharedProps.Caption = "Skids:";
comboSkidCountTool.SelectedIndex = 1;
comboSkidCountTool.DropDownStyle = Infragistics.Win.DropDownStyle.DropDownList;
//comboSkidCountTool.Value = "<Select a comnposer>";
comboSkidCountTool.SharedProps.ToolTipText = "How Many Skids Do You Need?";
comboSkidCountTool.AutoComplete = true;
comboSkidCountTool.SharedProps.AppearancesSmall.Appearance.Image = EpiUIImages.SmallEnabledImages.Images[EpiUIImages.IndexOf("Material")];
// Modify the Existing NewTool
baseToolbarsManager.Tools["NewTool"].SharedProps.Caption = "New Design";
// Create a Add Label Button
Infragistics.Win.UltraWinToolbars.ButtonTool NewLabelToolItem = new Infragistics.Win.UltraWinToolbars.ButtonTool("NewLabel");
NewLabelToolItem.SharedProps.Caption = "Add Label";
NewLabelToolItem.SharedProps.Enabled = true;
NewLabelToolItem.SharedProps.Visible = true;
NewLabelToolItem.SharedProps.AppearancesSmall.Appearance.Image = EpiUIImages.SmallEnabledImages.Images[EpiUIImages.IndexOf("Material")];
// Create a Print Button
Infragistics.Win.UltraWinToolbars.ButtonTool PrintToolItem = new Infragistics.Win.UltraWinToolbars.ButtonTool("PrintTool2");
PrintToolItem.SharedProps.Caption = "Print Labels";
PrintToolItem.SharedProps.Enabled = true;
PrintToolItem.SharedProps.Visible = false;
PrintToolItem.SharedProps.AppearancesSmall.Appearance.Image = EpiUIImages.SmallEnabledImages.Images[EpiUIImages.IndexOf("Print")];
// Register our Buttons with the Base Toolbars Manager
//baseToolbarsManager.Tools.Add(NewLabelToolItem);
baseToolbarsManager.Tools.Add(PrintToolItem);
baseToolbarsManager.Tools.Add(skidToolLbl);
baseToolbarsManager.Tools.Add(comboSkidCountTool);
// Add the NewLabel Button also to the Root Toolbar
//baseToolbarsManager.Toolbars["Standard Tools"].Tools.AddTool("NewLabel");
mainToolBar.Tools.AddTool("SkidCountLabel");
mainToolBar.Tools.AddTool("SkidCount");
// Add the Buttons to our Popup (DropDown) New Button Group
((Infragistics.Win.UltraWinToolbars.PopupMenuTool)baseToolbarsManager.Tools["NewMenuTool"]).Tools.AddTool("NewTool");
//((Infragistics.Win.UltraWinToolbars.PopupMenuTool)baseToolbarsManager.Tools["NewMenuTool"]).Tools.AddTool("NewLabel");
((Infragistics.Win.UltraWinToolbars.PopupMenuTool)baseToolbarsManager.Tools["NewMenuTool"]).Tools.AddTool("SkidCount");
For the dropdown you can use ToolValueChanged
private void UD08Form_ToolValueChanged(object sender, Infragistics.Win.UltraWinToolbars.ToolEventArgs args)
string sSkids = ((Infragistics.Win.UltraWinToolbars.ComboBoxTool)(args.Tool)).Text;
You can see the dropdown in this vid
