I’ve created a customization for UD24 Entry. I have a single combo-box that is tied to SalesRep BO so I have a list of available sales reps. Then I have an ultragrid that is bound to UD24 EDV. I want to refresh the grid so it is filtered to Key1 = SalesRep in the combobox. Any advice?
I bet I need to call a GetRows method and structure the where clause to be Key1 = combobox value. Does that sound about right? If yes, I can probably muddle my way through this.
Could you handle that as a dashboard (with an advanced search) embedded in the form, I wonder? I think I’ve seen a wizard for that but I haven’t used it yet.
I am tracking with you… but I can’t get the initial table to pull in to be able to filter it. On the default form, when you click the Search button it opens a new search window and it returns all the rows in the table (if you choose not to filter)… then you would pick from that list. I need to get that list of rows to populate in the grid when the form is loaded. Kind of like a dashboard that auto-refreshes when it’s loaded. Alternatively, the form can load with nothing in the grid if the I can get the grid loaded when I make a selection from the combo box that already filters to that sales rep.
I have tried to use the UD24 adapter with GetRows and GetList on the form load event, combo change event, as well as a button click. Nothing fills my grid with anything. I have hard coded the where clause to a value I know has entries.
@ckoch - I need to be able to delete rows from this screen also so I didn’t go the route of a UBAQ/dashboard.
