UD Field to PartRev
What Karl said. Thanks Marco!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl Dash
Sent: Wednesday, August 08, 2012 6:58 PM
Subject: Re: [Vantage] UD Field to PartRev
Marco, VERY cool. I've probably seen that program a thousand times and casually thought "Huh, I wonder what that does??!"
-Karl
From: Marco Vissuet <mvissuet@...<mailto:mvissuet%40pacificcontours.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Wednesday, August 8, 2012 3:03 PM
Subject: RE: [Vantage] UD Field to PartRev
You can... or you can link the fields through Custom Field Map... found under System Management, Utilities
Marco Vissuet
Systems Engineering
Pacific Contours Corporation
Office (619) 670-3900
Fax (619) 670-1643
mailto:marcov%40pacificcontours.com<mailto:mailto:marcov%40pacificcontours.com>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Karl Dash
Sent: Wednesday, August 08, 2012 2:35 PM
To: Vantage Group
Subject: [Vantage] UD Field to PartRev
I want to use a user-defined field in the ECORev table(Character01) to transfer info in turn to PartRev.Character01. After putting values into ECORev.Character01 and then checking the assembly back in I don't see the value being migrated to PartRev.Character01. Do I need to write a BPM to push the value to PartRev? Progress 803.408.
Thanks, - Karl
Â
Thanks, - Karl
Marco Vissuet
Systems Engineering
Fax (619) 670-1643
marcov@...<mailto:marcov@...>
To: Vantage Group
Thanks, - Karl
-Karl
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Â
Marco Vissuet
Systems Engineering
Fax (619) 670-1643
To: Vantage Group
Thanks, - Karl
