I try to stay away from the PartTran table all together for customizations. Is there another way you can achieve your results via a UD table? When I do have to hit the PartTran, I do it via a BO rather than a DD.
@jdtrent I don’t write to PartTran in a customization, but on End Activity I accumulate data in a json and put that into Callcontext Character01 which Epicor carries to the bpm in which I update PartTran post processing on the server side.
The write is still relative quick as it is only a couple of fields, but even if it was slow the user would be unaware.
I need to transfer some data on the handheld job receipt to inventory to the PartLot record. I’ll probably go the call context route that Greg mentioned.
