UD Field in BAQ
I created a BAQ for Part information, including a UD field that was created in Part_UD. Engineers fill in the information for this field when they create the part. In Purchase Order Entry, I created a new DataView using this BAQ so I could add the UD field. Then I added a text box for the UD field to the Line Detail screen and set the epbinding to the UD Field in the PartCerts dataview. However, when I run the preview, it doesn’t pull in the information from the Part_UD field. Not sure what I’m doing wrong.
Is the dataview bound to anything that would set the row?
Using the guided setup, it created an event. Is that what you mean?
My brain is stuck in classic land, sorry.
