UD Columns
Hi all. I’ve got a UD column set up that I want to add to a PO Header screen.
I’ve got the column set up, regenerated data models and recycled the application pool. How do I go about the next step of physically adding it to an existing table for users to access?
The only help I’ve found on this is how to set it up, not on actually adding it for users to access.
you will need to customise the screen to expose it to the users, and deploy the customisation
What application / screen would I use to do that? I’m not familiar with it.
Disregard. I got it pulled up.
Thank you.
