Two of my users are experiencing the same issue, but only them.
Epicor shuts down on its own, seemingly random.
Internet is excellent.
Windows quota set to max
The event logs show very little during her work hours except for this:
Error: Application Hang
The program Epicor.exe version 3.2.600.6 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Sounds like either a network issue or dot net. If they have wireless and wired connection I would verify that they are only using one and the card is not allowed to sleep to save power. Also see if there is something unique about the dot net version on each PC. I’ve seen similar issues that were very hard to track down and found a unique version of dot net on the clients created the same odd behavior…
