I have been assigned the task of “CLOSING” all quotes prior to 01/01/2018.
I created a BAQ and Dashboard that contained the following fields:
QuoteHed_QuoteNum
QuoteHed_DateQuoted
QuoteHed_QuoteClosed
I thought I could simply
A. Run the Dashboard and copy the data to Excel.
B. Chage the QuoteClosed column to True.
C. Then paste it back into Epicor.
It APPEARS to work at first.
But, when I run the BAQ afterwards to test the data everything shows up as FALSE - or not being Closed.
One thought I had is that the CLOSED status might be tied to the “Complete / Win / Lose” Options on the Header Task.
Unfortunately, no.
I have mentioned it would make my - and the company’s - life much easier.
But it is not in the budget for this year.
I am actually the “new kid on the block” at my company (about 6 months) with no prior Epicor experience.
But because of my past experience with implementing systems I was designated as the one to take on tasks such as this.
I have not tried to mass close quotes, but I can tell you that there is a switch in Company Config to allow/not allow changes to ‘quoted’ quotes. This would need to be set to allow in order for an Updatable BAQ to process correctly - we’ve had this problem trying to change other data regarding a quote. The task issue might be a problem as you identified. If a Task is marked as a milestone, the task must be dealt with. Otherwise I think you would be OK with the UBAQ method.
DMT - yes, would be easier - but I’m still not sure about the Milestone Task issue when using DMT.
Idea - Possibly a two pass issue - an UBAQ to deal with the associated milestone tasks, and the second for closing the quotes.
Actually I think that marking the Win/Lose task as ‘Lost’ will also close the quote. If your mandatory task set has only one task, then you’re in business, otherwise you might need to do two passes at the Task UBAQ. Everyone sets up tasks a little differently, so I’m guessing a bit here.
I know this is a really old post but I was trying to do the same thing and came across this post because there doesn’t seem to be anything more recent regarding this specific situation. After some trial and error I was able to successfully close old quotes by using DMT to close out the milestone tasks, and so I wanted to share my steps in case anyone else needs to do the same.
Made a BAQ to pull the list of tasks I wanted to close. I included the Task table with the following fields: Company, RelatedToFile, Key1, Key2, Key3, Sequence, Complete, Conclusion, ReasonCode, SalesRepCode. Those Task fields are all you’ll need for the DMT process, but in the BAQ I also linked the QuoteHed table so I could see some info about the quotes (EntryDate, ExpirationDate, QuoteClosed, ReasonType, ReasonCode). In the Task table the Key1 field had the quote number so I used that field to join the Task table to the QuoteHed table.
Before running the BAQ I used table criteria to filter down to the tasks/quotes I want to close. I added criteria to the Task table to only include tasks that are open (Complete = no), and I added criteria to the QuoteHed table to only include quotes entered prior to a certain date (EntryDate <= 01/01/2023).
**If the task is assigned to a user who is inactive you will get an error when you run the DMT process. So you’ll need to look at the SalesRepCode field and make sure you identify any users who are now inactive. Using the Work Force module, make them active again by unchecking the inactive box. After you run the DMT process you can mark them inactive again.
Run the BAQ and export to excel to make the spreadsheet you will use in DMT. My spreadsheet included these fields: Company, RelatedToFile, Key1, Key2, Key3, Sequence, Complete, Conclusion, ReasonCode (everything I pulled from the Task table except the SalesRepCode). The first 6 fields I left unchanged. On all the records change Complete to TRUE, set the CompleteDate to whatever date you want, set Conclusion to either WIN or LOSE, and enter your ReasonCode (this must match one of the reason codes you have in your task dropdown).
In DMT search for “Task List”. You may want to use the template generator to make sure it matches the spreadsheet you just made. Now you’re ready to process your file. Of course you may want to do a test run with just a few records.
If you made any inactive users active, remember to mark them inactive again
