Start simpler...Just use one of the tables to get the data >=07/01/2013...Then, once you have that data verify the values for a couple of records for the fields that you want to link (Company and emplink).
Try another BAQ with the second table data >=07/01/2013 and company = value from first BAQ and emplink = value from first BAQ - see if you hang or not...
Also, look at the data dictionary for the two tables to see what are the key indexes...
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of Trzaska, Mark
Sent: Wednesday, July 24, 2013 9:07 AM
To:
Subject: [Vantage] Re: trying to create simple baq for employee check detail
Well,
Jumped the gun on this one. I said I was okay. But im not.
Heres what I got.
Selected tables
PREmpMas
PRChkDtl
Table Relations
Each prempmas(parent) empid (keyid) prchkdtl (child)
Field relations
Company company
Emplink emplink
Sure enough the query just hangs. Did a selection for checks dated >= 07/01/2013 as to narrow down and test results
As a refresher im simply trying to create an executive format for payroll check register. (i.e. employee xxx check # xxxx amount $ xxxxx
Its quite obvious that im linking soething wrong. Whats bothering me is ive done baq with a heck of a lot more tables then this and had no problems linking. This on on the other hand is driving me insane.
Thanks for any help.
Mark Trzaska
Administrator
Stanley Machining & Tool Corp.
425 Maple Avenue
Carpentersville, IL 60110
Phone (847) 426-4560
Fax (847) 426-6951
e-mail
Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:
Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com>>
