I’m trying to create a BAQ (to be eventually used as the basis for a dashboard) for viewing (what we call) productivity. I have a subquery using LaborHed that gets the total payroll hours. I have another subquery using LaborDtl that gets indirect, direct, and earned hours. But if I want to set a date range, I need to manually set the range on each of the 2 subqueries. I’ve remade the BAQ a few different ways, but have not yet figured out how to get the date parameter(s) to the top level.
Here is the sql:
select
[EmpBasic1].[Company] as [EmpBasic1_Company],
[EmpBasic1].[EmpID] as [EmpBasic1_EmpID],
[EmpBasic1].[Name] as [EmpBasic1_Name],
[Header].[Calculated_TotPayHrs] as [Calculated_TotPayHrs],
[Detail].[Calculated_IndirectSum] as [Calculated_IndirectSum],
[Detail].[Calculated_DirectSum] as [Calculated_DirectSum],
[Detail].[Calculated_TotEarned] as [Calculated_TotEarned],
(CASE WHEN Header.Calculated_TotPayHrs = 0 then 0 ELSE Detail.Calculated_DirectSum / Header.Calculated_TotPayHrs end) as [Calculated_DirectProd],
(CASE WHEN Header.Calculated_TotPayHrs = 0 then 0 ELSE Detail.Calculated_TotEarned / Header.Calculated_TotPayHrs end) as [Calculated_EarnedProd]
from Erp.EmpBasic as EmpBasic1
inner join (select
[EmpBasic].[Company] as [EmpBasic_Company],
[EmpBasic].[EmpID] as [EmpBasic_EmpID],
[EmpBasic].[Name] as [EmpBasic_Name],
(sum(case when LaborDtl.ExpenseCode = 'Indirect' then LaborDtl.LaborHrs else 0 end)) as [Calculated_IndirectSum],
(sum(case when LaborDtl.ExpenseCode = 'Direct' then LaborDtl.LaborHrs else 0 end)) as [Calculated_DirectSum],
(sum(LaborDtl.EarnedHrs)) as [Calculated_TotEarned]
inner join Erp.LaborDtl as LaborDtl on
LaborDtl.Company = EmpBasic.Company
and LaborDtl.EmployeeNum = EmpBasic.EmpID
group by [EmpBasic].[Company],
[EmpBasic].[EmpID],
[EmpBasic].[Name]) as Detail on
EmpBasic1.Company = Detail.EmpBasic_Company
and EmpBasic1.EmpID = Detail.EmpBasic_EmpID
inner join (select
[EmpBasic2].[Company] as [EmpBasic2_Company],
[EmpBasic2].[EmpID] as [EmpBasic2_EmpID],
[EmpBasic2].[Name] as [EmpBasic2_Name],
(sum(LaborHed.PayHours)) as [Calculated_TotPayHrs]
from Erp.EmpBasic as EmpBasic2
inner join Erp.LaborHed as LaborHed on
EmpBasic2.Company = LaborHed.Company
and EmpBasic2.EmpID = LaborHed.EmployeeNum
group by [EmpBasic2].[Company],
[EmpBasic2].[EmpID],
[EmpBasic2].[Name]) as Header on
EmpBasic1.Company = Header.EmpBasic2_Company
and EmpBasic1.EmpID = Header.EmpBasic2_EmpID
I’m not sure how to rebuild this, because this is the only way that I get any decent results.
