I think I know what my issue is but don’t know how to fix it.
UD110Adapter uAdpt = new UD110Adapter(UD110Form);
uAdpt.BOConnect();
// Load the matching record in the UD110 table...
bool MorePages;
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.NamedSearch.WhereClauses.Add("UD110A", "Key1 = '" + JobNum + "' AND " + "Key2 = '" + PartNum + "' AND " + "Key3 = '" + AsmSeq + "' AND " + "ChildKey1 = '" + Serial + "'");
opts.PageSize = 0;
DataSet ds = uAdpt.GetRows(opts, out MorePages);
ds.Tables["UD110A"].Rows[0]["Date08"] = ThisDate;
uAdpt.Update();
The update at the bottom refers to the UD110Adapter but I don’t know how to make the changed ds.Tables[“UD110A”].Rows[0][“Date08”] record update as well.
So the other thing that some methods need is a before and after row. So before you make changes, copy the row, then make the the changes on one of the rows. So the row mod for one of them will be U and the other won’t have a row mod. This is the unchanged row. Use BufferCopy.Copy(rowfrom, rowtoo); to make the copy.
uAdpt.BOConnect();
uAdpt.GetByID(JobNum, PartNum, AsmSeq, "", "");
// Loop through UD110A to find the serial in ChildKey1 and update the date field in ColN
foreach(DataRow dr in uAdpt.UD110Data.UD110A.Rows)
if(dr["ChildKey1"].ToString() == Serial)
dr.BeginEdit();
dr[ColN] = ThisDate;
dr.EndEdit();
ah, I was in server side code world in my head. We try to do as little as possible on the client side since all that code will be basically useless once you get to kinetic web UI. I’m glad you figured it out.
