I have to correct myself here. In 5.0 at least, the Cost Set Entry feature (used to be called Standard Cost Rollup), allows you to set new Standard costs for your Manufactured AND Purchased parts depending on a number of options that you select. One such option allows you to copy the current average costs for each part over to the Standard. Or you can "roll up" costs to create a standard cost according to what your burden and workcenter costs are to 'simulate' what standard should be.
Thanks to Doug Williams, Director of Development at Epicor, for the explanation of how it works.
Troy
Troy
----- Original Message -----
Sent: Thursday, April 26, 2001 6:01 PM
Subject: Re: Re:[Vantage] Transferring Ave Unit Cost to Standard Unit Cos
ABOM Standard Cost Rollup won't work for us for two reasons:
1. It doesn't update the Standard Cost on Purchased parts.
2. It adds up labor steps at the current burden rate. We need it to simply transfer the current Ave cost and make it the new standard cost. That way our inventory value won't change during the transfer. Later we will adjust the Standards to be more accurate.
So, we are looking for a nifty method of changing the average cost for each part and copy it to the appropriate standard cost field for that part.
Troy Funte
Liberty Electronics
To: vantage@yahoogroups.com ; vantage@yahoogroups.com
Sent: Wednesday, April 25, 2001 6:32 PM
Subject: Re:[Vantage] Transferring Ave Unit Cost to Standard Unit Cos
Hi Troy,
Are you not wanting to utilize the Standard Cost Replace in the ABOM to
populate the standard costs? Or are these purchased parts?
Mike Lowe
Connor
____________________Reply Separator____________________
Subject: [Vantage] Transferring Ave Unit Cost to Standard Unit Cost
Author: <vantage@yahoogroups.com>
Date: 4/25/2001 6:16 PM
Hi progress gurus,
I had some excellent help from some individuals using progress to convert our
9,323 parts from Average to Standard cost, and also to eliminate some errant
country codes in 3.0 before our conversion to 4.0.
Now, I have 9,323 parts with 0 (zero) Standard Cost. Anyone have a simple,
fast way to transfer the current Average cost of each part over to it's Standard
Cost field? (This would apply to each unit Burden, unit Labor, unit Material).
We really don't care if there is no Transaction History on these parts (as
would happen if you did a cost adjustment) since the inventory should be exactly
the same value before and after the transfer of the costs.
This could be done in Vantage 3.0 or 4.0 or 5.0 since that's where we're
heading anyway.
Another option might be to do this using Access, linking live through ODBC. Any
comments on that as well?
Troy Funte
Liberty Electronics
To access the Files Section of our Yahoo!Group for Report Builder and Crystal
Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Received: from mu.egroups.com [64.211.240.238] by cfmp.com (ccMail Link to SMTP R8.31.00.5)
; Wed, 25 Apr 2001 15:17:41 -0700
Return-Path: <sentto-20369-20574-988237033-MLowe=CFMP.COM@...>
X-eGroups-Return: sentto-20369-20574-988237033-MLowe=CFMP.COM@...
Received: from [10.1.4.53] by mu.egroups.com with NNFMP; 25 Apr 2001 22:17:13 -0000
X-Sender: tfunte@...
X-Apparently-To: vantage@yahoogroups.com
Received: (EGP: mail-7_1_2); 25 Apr 2001 22:17:12 -0000
Received: (qmail 7274 invoked from network); 25 Apr 2001 22:17:12 -0000
Received: from unknown (10.1.10.26) by l7.egroups.com with QMQP; 25 Apr 2001 22:17:12 -0000
Received: from unknown (HELO moose.erie.net) (208.138.204.11) by mta1 with SMTP; 25 Apr 2001 22:17:11 -0000
Received: from ashton (pmc5-21.erie.net [63.174.20.150]) by moose.erie.net (8.11.1/8.11.1) with SMTP id f3PMGeg07335 for <vantage@yahoogroups.com>; Wed, 25 Apr 2001 18:16:40 -0400 (EDT)
Message-ID: <015601c0cdd5$5abf2ba0$34ce8ad0@ashton>
To: "Vantage" <vantage@yahoogroups.com>
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 5.50.4133.2400
X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact vantage-owner@yahoogroups.com
Delivered-To: mailing list vantage@yahoogroups.com
Precedence: bulk
List-Unsubscribe: <mailto:vantage-unsubscribe@yahoogroups.com>
Date: Wed, 25 Apr 2001 18:16:17 -0400
Reply-To: vantage@yahoogroups.com
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Yahoo! Groups Sponsor
Click Here to Find Software Faster
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
