Hello all, I’m setting up a new installation of Epicor for an upgrade. This new installation is on a completely separate server from the previous installation. The new installation is Kinetic 2022_1 on Server 2019, and SQL 2019. The previous installation is ERP10.2.400.18 on Server 2012R2 and SQL Server 2014. Of course none of our custom reports or data sources are on the new installation. Is there a quick and easy way to transfer all of the reports from the old installation to the new? Any help on this would be greatly appreciated, thanks!
This is what you want:
There are also PowerShell scripts out there that work as well.
@kjconner You can also use the solution workbench, but be careful of system RDDs as they can slide into a build. We had an issue the MtlTag RDD that got added to a cab
