Transfer Order - Detail Memo
I am creating a BAQ that link Transfer Order line detail to the Memo. When we create a line memo, it puts it in the Ice.Memo table. The Key1, I thought that’s the transfer order number, but doesn’t seem like it is. If I create a new memo, the ID in the Key1 is totally different. Anyone know which other table needs to be linked? I can go into Transfer Order Entry to the line detail and the memo is there. Other memo seems to match though. For example, in Order Entry if I create a line memo, the Order Number matches. Why transfer order does not match, no clue.
I figured it out now. Thinking it’s like the other tables, TFOrdDtl have a field called TFLineNum. After joining this, it worked.
The Memo Table has a “RelatedtoSysRowID” column. Join the SysRowID of the Line Detail record to the RelatedtoSysRowID of the Memo to get all the Memo rows related to the Line.
Ah thank you. Didn’t know you can do that as well.
