Hi Al,
or Visual Basic for Applications. This is NOT the same as VB or VB.Net - which
are different from each other as well.
.Net is Microsoft's answer to Java, which is a single programming language
that compiles to bytecode which is then executed by a virtual machine. .Net is
a framework for multiple languages (VB.Net, C#.Net, Colbol.Net, etc.) that
compile to run on the Common Library Runtime or CLR. Technically, you can run
.Net applications on Linux using the Mono Project.
(http://www.mono-project.com)
Epicor uses .Net (C# for the client and VB.Net for customizations) and Java
for the Server side (OpenEdge), but I don't think you see any of that.
From what I've picked up here on the list and from playing around, Epicor has
gone all-in with .Net - which includes its data model: ADO.Net. So just the
get the vernacular down, I would get Visual Studio.Net 2003 or above. Then I
would read up on ADO.Net. Learning about DataSets, DataAdapters, etc. will
make it easier to understand Vantage objects. And of course, Google is your
friend:
http://www.programmingtutorials.com/vbnet.aspx
http://samples.gotdotnet.com/quickstart/howto/doc/adoplus/ADOPlusOverview.aspx
Sorry for rambling... This is live week here, so I guess we're the 11th
company on 8.03. We're not using all of the features of course but getting
along - so far....
Mark W.
> So the question is what track would you suggest I begin looking at toOffice applications (like Access, Word, and Excel) and tradition ASP use VBA
> get familiar with VB and VB.NET? Would starting with ACCESS and VB work
> or should I start with something else?
friend:
along - so far....
Mark W.
