They must have changed it somewhere between 5.2 and 8 to lock it down.
That is too bad, b/c we are often re-opening them to update the RMA# and
print the packing slip. I guess when we go to 8 we will have to change
our procedure to have purchasing get the RMA before rejecting the parts
in RMA! Thanks!
Of Dupuis, Mark
Sent: Tuesday, October 21, 2008 1:28 PM
Subject: RE: [Vantage] Tracking Vendor Nonconformances
Hi Sarah
On version 8.00.812 we can re-open the DMR but all the fields on the
reject tab remain grayed out. There does not appear to be a way to
re-open the reject. The RMA# is here on the reject tab.
Mark D
Of sarah.vareschi@...
Sent: Tuesday, October 21, 2008 11:08 AM
Hi Mark... your note "We found that you cannot enter the vendor RMA in
DMR
processing after the parts have been rejected."
Just FYI: We are several versions back so this may have changed in 8.x
versions... but back here on 5.2 you can re-open the DMR (go to DMR
Header and click 'open') and then you can enter in the RMA# even if
items were previously rejected, and then just re-close it.
And, our process is very similar as you described below.
-Sarah
<DIV><font size="1.5" face="Bookman Old
Style">__________________________________________________________
This email may contain material that is confidential, privileged and/or
attorney work product for the sole use of the intended recipient. Any
review, reliance or distribution by others or forwarding without express
permission is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
__________________________________________________________<DIV><FONT>
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
in RMA! Thanks!
Of Dupuis, Mark
Hi Sarah
Mark D
DMR
-Sarah
