Yes, we have APM. Basically, I need to track if the SOA has been sent or not (while we're sending them manually) until Epicor releases 410 which contains fixes that will allow us to auto-print the SOA through a BAM to our APM printer.
--- In vantage@yahoogroups.com, "Nick" <nick@...> wrote:
> Do you have any fo the APM functionality? If so, you can use that to send
> you an email at the same time the SOA has been sent.
> On Wed, 26 Oct 2011 20:52:56 -0000
> "Jeff Rogers" <jeff.rogers@...> wrote:
> Does auto-printing the SOA through a BAM actually work
> for you? We're on Vantage 8.03.409a and when I tested
> auto-printing the SOA it showed up in the system monitor
> with an error stating "no records found". Epicor support
> stated this is a known bug and will be fixed in their 410
> release due out in December '11. Thanks for the input.
> Your suggestion is pretty much what I want to do if
> auto-print works.
> --- In vantage@yahoogroups.com, Joe Rojas <jrojas@>
> wrote:
> > I use a BPM in order to determine when the auto print
> >should take place.
> > In our case, when and order is taken off of hold.
> > When this happens, the BPM sets a UD checkbox to true and
> >then I have a
> > BAM that monitors for this change.
> > The BPM also stores the date and time that the UD
> >checkbox was set to
> > true.
> > This gives me an indication of when the auto print job
> >took place but it
> > does not indicate if the APM job faxed correctly.
> > From: vantage@yahoogroups.com
> >[mailto:vantage@yahoogroups.com] On Behalf
> > Of Jeff Rogers
> > Sent: Wednesday, October 26, 2011 4:14 PM
> > Subject: [Vantage] Tracking if the Sales Order
> >Acknowledgement has been
> > sent
> > We have a need to track if the Sales Order
> >Acknowledgement has been sent
> > (printed through our APM printer) for each order. Ideally
> >a flag would
> > be set on the order header record after the form is
> >printed (either
> > through a BAM that auto-prints, or manually printing the
> >SOA). Does
> > anyone have any ideas on how this would be implemented?
> >Thanks!
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-9278 | fax:
> >781-232-5191
> > jrojas@ | www.matsinc.com Ask us about our clean,
> >green and beautiful matting and flooring
> > This message is intended only for the individual named.
> >If you are not the named addressee you should not
> >disseminate, distribute or copy this e-mail. Please notify
> >the sender immediately by e-mail if you have received this
> >e-mail by mistake. Please note that any views or opinions
> >presented in this email are solely those of the author and
> >do not necessarily represent those of the company.
