Yeah I could do it however it is very subjective and adding a config file is just too complex #NotWorthIt
However if you get enough support behind it… Maybe I’ll have a crack at it… also it’s
FLOSS so anyone else can try and add that feature we’ll accept pull requests LoL
Speaking of which anyone wanna volunteer to update the Readme.md file on the repo with the info here? I hate mark down lol #AskingForAFriend#IHateWritingDocs
Is it common to see this in your update methods. After several traces in various BOs, I see my values in decimal and integer form. These are canned methods, not anything I have tinkered with or altered.
Just curious if its a trace artifact, or if the values are actually changing types.
I’m not sure if it’s been fixed yet, but in my version, when you travel back to the method selectors, if there are multiple entries of the same method name, the dropdown looses track of where you were – it always reselects the first matching method name by name vs. where you were in the list (eg. the 2nd method of the same name).
If it’s just a matter of reselection and you’re matching by name, you could just preceed the dropdown control with a line instance to help the control locate on its own. For example, in this scxreenshot I’m moving down the list method by method doing DIFFs. You can see that I’m down to the last UpdateMaster method, but when I reselect one of the pulldowns, it just back up to the first matching name in the list.
You have to pick a different prior method. The code is to show you what you need to change. You have the same methods in the before and after, so there is no change.
